bypass
hello i have a avic 90bt and i am looking to do the bypass on it. i know about the yellow mute wire, but where does the pink car speed input go to? please if anyone knows let me know. i also have an 08 350z non-bose. also the problem im having is that i keep reading aobut a VSS wire. now i did not buy the aftermarket harness for metra, i got mine from bestbuy. its dynex. can i still do the bypass with this harness?
Are you wanting the VSS wire or Tach wire?
Just in case:
VSS WIRE Blue/black At module below radio in console 8000ppm
I think it's pin 26, of the gray 16 pin plug.
Just in case:
um i have no idea lol i just wanna do the bypass right and i getting different answears from all over. do i even need to use the pink car speed input wire to make the bypass work?
heres my next question, i took apart the dash and i find that my headunit has 3 harnesses hook into it. the avic is only guna have the two harnesses. do i just leave that little brown harness be or do i splice that somwhere?
Thats the harness for the steering wheel controls. If you have the PAC steering wheel control adapter then that is the connector you use. If you are not going to be using your steering wheel controls then leave it disconnected.
Beater350z
Sep 9, 2015 03:36 PM
