First ever in a 350z!
Old Oct 1, 2003 | 05:46 AM
the doc's Avatar
the doc
Default First ever in a 350z!
I'm pretty sure this is the first design of its type in a 350z. I wanted a ported enclosure to fit in the space behind the driver's seat...this first pic shows the first box I built that fit through the rectangular opening, but it wasn't enough air space
Old Oct 1, 2003 | 05:48 AM
the doc's Avatar
the doc
This shows the sides of the enclosure, 3/4" MDF, cut to fit closely to the contours of the metal...
Old Oct 1, 2003 | 05:49 AM
the doc's Avatar
the doc
Here's the front panel of the encl...
Old Oct 1, 2003 | 05:51 AM
the doc's Avatar
the doc
Now the finished product. Kicker comp VR 8 with approximately 200-225 watts on each voice coil. The amp is a cheap Phoenix gold that bought from a friend years ago for $70, but it does the job!
Old Oct 1, 2003 | 05:53 AM
the doc's Avatar
the doc
This panel was rattling quite a bit, but some 3/4" foam tape took care of that With the panel in place everything looks factory...
Old Oct 1, 2003 | 05:56 AM
the doc's Avatar
the doc
Here's the port...I drilled a 2.5" hole for the 2" PVC port to pass through. It's sealed with a plastic flange and silicone caulk. It is between the speaker bar and the rear STB in the trunk. Eventually I will fiberglass it to make it more visually appealing
Old Oct 1, 2003 | 06:02 AM
the doc's Avatar
the doc
This setup sounds amazing for it only being an 8" sub! I can use my Alpine HU to dial in tight, punchy bass or very deep, boomy bass. There are no rattles or air leaks as I used silicone and Great Stuff foam to seal everything.
Some pics of the rest of my system...
Old Oct 1, 2003 | 06:03 AM
the doc's Avatar
the doc
XM tuner installed in secret compartment in glove box...
Old Oct 1, 2003 | 06:04 AM
the doc's Avatar
the doc
Finally, XM antenna on rear strut tower brace. Opinions/comments/questions welcome, and thanks for viewing!
Old Oct 1, 2003 | 06:16 AM
jj1814's Avatar
jj1814
nice.
where in the dirty, dirty?
Old Oct 1, 2003 | 06:36 AM
the doc's Avatar
the doc
Upstate SC, I'm so ready to move out west!
Old Oct 1, 2003 | 07:44 AM
ddtreadway's Avatar
ddtreadway
You do all the work yourself, doc?
I live in Spartanburg, and have a client who does this work, so I was wondering.
Old Oct 1, 2003 | 07:53 AM
the doc's Avatar
the doc
Yeah I did it all. I never removed the driver's seat, so it was difficult working inside that space (my back is still pissed at me ) I've done installs in my previous 5 vehicles, but this one was the most challenging.
Btw, I'm down the road in Anderson
Old Oct 1, 2003 | 01:21 PM
chia's Avatar
chia
those are some very nice pictures, where is taht port hole??? i dont see where it is coming out of. I've done custom auto work on my preivous 3 cars, and now i'm pondering on what i will do with my new Z.
I want to fit a 10 sub in that space behind seat. I want to have mucho bass since in my last car i had 2 15s!
Old Oct 2, 2003 | 03:27 AM
the doc's Avatar
the doc
The port is just forward of the rear strut tower brace, on the driver's side. It is just behind the separation that houses the rear 6.5's, letterboxes, and glove box. It fires into that corner on the left side.
I'm sure you could do the same thing with a 10", I just used an 8" because that's what I already had. Good luck!
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
