Please help!!!!!!!!!!!! Dash kit question
Old Aug 28, 2009 | 08:37 PM
romeo62186's Avatar
romeo62186
Default Please help!!!!!!!!!!!! Dash kit question
Hi guys. I am in the process of installing my Pioneer Avic-Z2 in my 2003 350z and I am just so confused about something. Searching old threads...mostly everyone seems to say that all you need is one piece from the dash kit. What piece is this exactly?!?!?! Could someone please circle it from the picture below...
http://www.crutchfield.com/App/Produ...z+dash&tp=3121
I however didn't go with the Metra kit. I chose the American International kit from ebay...
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Everything pictured in the listing is ALL that I received. It states no cutting is required yet in the instruction booklet...it clearly states that cutting and filing is required for double din units. So I let it slide and I did that. I then put the trim over my Avic...only to see that there is like an inch gap from the bottom of the screen and like a quarter inch gap from the top. Am I missing something here??? Did I order wrong part??? Why is there gap? Isn't the point of the kit to give it the OEM look? I am so confused. Thanks in advance for any gelp guys.
***EDIT*** Pic of what I mean in post #5
Old Aug 29, 2009 | 01:52 AM
$LiK RiK's Avatar
$LiK RiK
to make this quik.....order the crutchfield kit i got it an it fit perfect..worth the $15 2 days an you got it
Old Aug 30, 2009 | 07:49 AM
romeo62186's Avatar
romeo62186
Thanks guys. I still need more help.
Old Aug 30, 2009 | 08:20 PM
romeo62186's Avatar
romeo62186
This is what I mean. WHy is there a gap between my unit and the trim? Am I suppose to modify it? Why does it not fit? am I missing something?
Attached Thumbnails Please help!!!!!!!!!!!! Dash kit question-img00020-20090828-2316.jpg
Old Aug 30, 2009 | 09:16 PM
TheFarmer's Avatar
TheFarmer
romeo...I'm having the opposite problem from you. I'm using a cheapo dvd double din to replace a defective factory unit and the Scosche double din kit I got didn't even come close to sliding over the face, the Scosche kit was just too small. I ended up filing and cutting it to enlarge the opening but it jams when the unit opens to insert a CD lol.
Yours looks like it may actually fit mine. If you decide to sell it, PM me
Old Aug 30, 2009 | 11:48 PM
shadyonedeath's Avatar
shadyonedeath
you could always attach some velvet/fuzzy tape. The kind that stops squeaks.
Old Aug 31, 2009 | 03:31 PM
THEDUKE's Avatar
THEDUKE
You are holding it flush against one side of the kit. Once you install it, you will notice that it will be in the center of the trim ring which in turn you will have a small gap all the way around. You need this small gap so the unit opens and closes without rubbing issues. Also once you install it it will not have light coming thru so the actual gap will not look so bad.
Old Aug 31, 2009 | 04:33 PM
romeo62186's Avatar
romeo62186
I appreciate the help so far guys,.Thanks. That actually makes me feel a little better but are you sure that there is suppose to be that much gap? I am not holding the trim ring...that is with the trim already situated on the unit and it does not move. So I don't know about it moving towards the center. Also how come in every single picture I've seen on the forums I see ZERO gaps in everyone's setup. Am I just that unfortunate?
Old Sep 1, 2009 | 06:37 PM
romeo62186's Avatar
romeo62186
Please someone!!!
Old Sep 6, 2009 | 11:02 AM
romeo62186's Avatar
romeo62186
Guys. Please. I really don't want to spend another 20 dollars ordering another kit if not necessary. Am I suppose to modify this somehow. Is that huge of a gap normal? Or do I HAVE to order another kit to have that oem look because that gap is just ridiculous.
Old Sep 9, 2009 | 04:25 PM
romeo62186's Avatar
romeo62186
Originally Posted by bigaudiofanatic
How much gap are you talking about? If you have a picture that would help out a lot
I have a picture a few posts up.
Workshop12
Mar 23, 2020 01:45 PM
issyz
Jul 2, 2017 03:04 PM
Vigman
Nov 17, 2015 04:34 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
