looking for cheap 10" (P3 vs type r?)
Old Sep 21, 2009 | 10:52 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Default looking for cheap 10" (P3 vs type r?)
So I recently blew my eD e5.10 and am looking for an inexpensive replacement. I have an eD amp bridged that puts out 600w x1 @ 4ohms. I was orginally looking at the P3 10" until I talked to some of my co-workers. (I work at bby) For the money they recommended the alpine type r. Correct me if I'm wrong but I would need a D2 ohm sub to get the most out of my amp? What do you guys think P3 or type r, or any other suggestions for around $100, remember my budget is low so please don't recommend something expensive and say just save and get this. Thanks
EDIT: BTW I have a small sealed enclosure .56sqft so please keep that in mind.
Old Sep 22, 2009 | 02:07 AM
duro78's Avatar
duro78
type r will blow away a p3 especially in a ported enclosure where they really shine. Go to any car audio forum everyone swears by them for best bang for the buck. If you can since you get the discount buy another one get a new box made with at least 2.0 cu.inch of airspace and it will be very loud you would need a bigger amp though. Not sure if your amp is 1 ohm stable but I would wire 2 in parallel at 1 ohm. Im not sure about type r specs so dont quote on the ohms needed
Old Sep 22, 2009 | 04:14 AM
StreetOC192's Avatar
StreetOC192
If you are on a tight budget, I would really suggest my personal all time "performance per dollar" leader. Pioneer subs have always done a stellar job for the price. I think your store sells these, so you might be able to get it pretty cheap with the discount. This sub is well suited to most of the prefab 350z sealed enclosures.
http://www.woofersetc.com/p5200/TSW2...-Subwoofer.htm
I'm not too sure which eD amp you have because the nine.2 is rated at 400x1@4ohms. That's the only 2 channel amp they have currently. I'm assuming you have a 2 channel because you mention in your OP that it is rated "bridged". But if your amp is only stable to 4ohms bridged (most likely), then you will want a dual 2ohm sub and wire it in series to show the amp a 4ohm load.
Old Sep 22, 2009 | 12:07 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
I have the nine.2x amp which they don't sell anyone. Its a larger then just the nine.2 and puts out more power. Its rated at 600w x1 @ 4ohms when bridged. Thanks for the recommendation I'll have to check them out. I'm not really looking at just bestbuy subs because most of there subs are either 12s or there D4 and not D2. Our discount is pretty good but anything there can be found online for the same as employee price.
Old Sep 22, 2009 | 01:59 PM
redlude97's Avatar
redlude97
Why not go ED 11kv.2/0v.2?
Old Sep 22, 2009 | 02:16 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
Was sort of disappointed with eD, would rather go with a larger brand for a more safe bet.
Old Sep 22, 2009 | 02:40 PM
doug's Avatar
doug
thank me later: https://ssl.perfora.net/www.ficaraud...iew.shopscript
Old Sep 22, 2009 | 03:58 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
somebody can't read my first post very well
Old Sep 23, 2009 | 05:10 AM
doug's Avatar
doug
so the plan is to keep buying $100 subs and blowing them? if so then find a forum and go used
Old Sep 23, 2009 | 03:54 PM
redlude97's Avatar
redlude97
how did you manage to blow your ED sub? Did you not set the gains properly? The e5.10 should have been able to easily handle 600wrms
Old Sep 23, 2009 | 06:16 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
there's no readon a $100 sub shouldn't be able to handle what I'm asking without blowing.
I didn't have the gain all the way up and it worked fine for a little over 6 months.
Old Sep 24, 2009 | 09:37 AM
redlude97's Avatar
redlude97
Did you set the gains with a multimeter? Just because it wasn't all the way up doesn't mean it wasn't clipping. Did you blow a VC?
Old Sep 30, 2009 | 07:56 PM
Moncef's Avatar
Moncef
If you're looking for a 10" Alpine Type-R, I can get you a brand new one in the box for $150 shipped. PM if you're interested.
Old Sep 30, 2009 | 10:22 PM
SoCal-Zzzz's Avatar
SoCal-Zzzz
nvm problem solved, btw a type r could be had for $100
Mikestoyz
Mid-Atlantic
Aug 6, 2006 04:08 PM
mhoward1
Sep 6, 2005 01:30 PM
