New install with interference
Old Oct 29, 2009 | 02:17 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Originally Posted by pauls350z
The noise is apparent at tick over and gets worse when put into gear and then reved.
Alternator noise is a whirring sound - ticking isn't from an alternator. This could be a rare case of fuel pump noise. I certainly know where the gas tank is, just under the subwoofer cavity where many of us mount our amplifiers ... so I'm assuming there's a pump under there. What is the frequency of the "ticking"? If it was a bad spark plug wire I would say it was a "popping" sound.
Old Oct 29, 2009 | 02:53 PM
Spike100's Avatar
Spike100
^^ Paul, He’s not describing this as a ticking noise. “At tickover” is a term used in Europe (meaning the car’s engine running at idle).
He's telling us the noise is apparent at idle, and becomes worse as engine speed increases.
--Spike
Old Oct 29, 2009 | 03:21 PM
jonny_q's Avatar
jonny_q
sounds like u have a grounding issue with the rca's or headunit. just throwing it out there but try grounding all the outter portions of the rca's together and u might notice ur problem is gone.
Old Oct 30, 2009 | 07:15 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
--Spike
Thanks my bad ... I should learn to speak English
Grounding it is.
Old Jan 6, 2010 | 09:50 AM
pauls350z's Avatar
pauls350z
Unhappy Final Update
Gents,
I finally sorted this by going back to 1 x RCA cable and decommisioning the other one
I took the single RCA out of the High Pass on the active crossover and then put on 2 x RCA doublers/splitters. This is not ideal as I have no real time control over front rear fade, but I have balanced to a suitable level on the amp and this works.
It is a shame but this is the solution as grounding, re-routing etc. did not work.
Thanks all.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
