Please help! Battery Died from car audio?
Old Nov 7, 2009 | 09:03 AM
dknydiep's Avatar
dknydiep
Default Please help! Battery Died from car audio?
Hey guys,
Just wondering why my battery died. Everything was working fine until I adjusted the gains yesterday. When I woke up for work, the car was completely dead. I attached a jump cable from my other car, and the car would still not start (but electronics turn on). I took my battery to Sear's and they said that the battery was good and holds a charge.
What's going on? Bad ground or something?
Thanks a lot guys,
J
Old Nov 7, 2009 | 09:15 AM
dknydiep's Avatar
dknydiep
Could it be because of the alternator?
Old Nov 7, 2009 | 03:39 PM
Z_Youlater's Avatar
Z_Youlater
This happened to me a few days ago, i had a ground left ungrounded. Check your harness for the headunit, the amp for the system if you have it, just recheck what you've done so far to your audio system, i would bet there's a ground left open.
Old Nov 7, 2009 | 06:42 PM
Spike100's Avatar
Spike100
I could be as simple as your battery cable(s) not being connected solidly. It's unlikely that the alternator is causing the problem.
Did the car start after you reinstalled the battery?
--Spike
Old Nov 7, 2009 | 08:46 PM
POWUH's Avatar
POWUH
make sure that ur mom revs her car when giving power
Old Nov 8, 2009 | 12:30 AM
240tog35's Avatar
240tog35
funny man
Old Nov 8, 2009 | 02:51 AM
StreetOC192's Avatar
StreetOC192
What does the car do when you turn the key to "Start"?
Do you hear the engine crank, do you just hear a clicking noise, do you hear nothing?
It could be anything until we know the answer to this to help narrow down possible causes.
Old Nov 8, 2009 | 08:13 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Sounds like you left an amplifier burning power. I had a cap with a fancy LED display and light show that would slowly drain my battery across two or three days of not driving it. Your power loss sounds much faster than a small load like that. The car's brain will actually shut off the headlights and even the dome lights so it's likely something like the headend or amplifier.
Good luck and let us know when you find the power drain.
SonnyWu
Nov 24, 2015 08:19 PM
OdesiTT
Sep 30, 2015 10:47 AM
Shane86
Sep 17, 2015 05:33 PM
Katie93
Sep 15, 2015 05:57 PM
