bose info needed...has it got crossovers ?
Old Nov 19, 2009 | 04:07 AM
y0k0m0's Avatar
y0k0m0
Default bose info needed...has it got crossovers ?
Hi
Ive swapped out my HU and sub for jvx av33 and apline sub driving my hertz sub and am now looking to swap out the front speakers.
so does the bose POS have a cross over to the tweets or doe si just send it all every where ?
all every wher ei gues smake it simple as i can just disconnect the tweets alteast .
Old Nov 19, 2009 | 05:53 AM
duro78's Avatar
duro78
pull all that bs bose out. Buy a set of decent components with there own crossovers
Old Nov 20, 2009 | 09:58 AM
y0k0m0's Avatar
y0k0m0
ok got the answer myself when i fixed my stuck window motor ... theres tiny capacitor on the tweet and thats it ! full range to both !
new question , do any afteramrket tweets fit int he oem holes without cutting ?
Old Nov 20, 2009 | 01:02 PM
Spike100's Avatar
Spike100
^^ I see that you answered your question about the OEM crossovers. The same is true for tweeters mounted in the sail panel. The stock mount in the sail panel is a tiny compartment meant to hold small and inexpensive tweeters. Even if you can find a quality tweeter that fits the sail panel, you may not want to mount the high frequency component here.
Personally, I think better positions for your tweeter are a custom kick, door pods, a cutout in the door panel, or the A-Pillar. Some members have also done custom mods to the sail panel so that it holds better aftermarket tweeters. To see these options, do a search on Audio & Video Forum where there are many discussions on tweeter-positioning.
--Spike
Old Nov 21, 2009 | 10:03 AM
y0k0m0's Avatar
y0k0m0
welli came up wit a solution .. buy some used oem mounts (sail panel is it?) and once ive got the comp/panel s im gonna wheel out the fiberglass etc an custom make some new mounts then cover in carbon fiber for looks unfortuantly no cash at the mo = going no past planning yet
kick builds would be best i need all the space i can get down there , A piller agin im asfter easy reverseal of mods so thats a no goo.
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
