Satellite Antenna
Old Nov 24, 2009 | 02:37 PM
Bilz's Avatar
Bilz
Default Satellite Antenna
My 2005 Touring Z was satellite ready so I found the NISSAN XM reciever and plugeed it in. I dont really like the antenna so, I bought what somebody called a "dead mouse" antenna (28208-CF41A) and the cover for it. Then: oh no! the fittings are different sizes. Does anyone know if this antenna will even work with my system?
Old Nov 24, 2009 | 02:40 PM
calin's Avatar
calin
Is this what you're talking about?
Old Nov 24, 2009 | 02:43 PM
Bilz's Avatar
Bilz
Default Yeah
Yeah.
Old Nov 24, 2009 | 02:46 PM
calin's Avatar
calin
So you're saying that the connections won't plug into your stock stereo? I'd call a Nissan dealer and see what they say. Maybe you need some kind of adapter to make it work
Old Nov 24, 2009 | 02:47 PM
Bilz's Avatar
Bilz
Default Antenna
Can you give any advice? Was the car in the picture pre-wired for that?
Old Nov 24, 2009 | 02:50 PM
Bilz's Avatar
Bilz
They are the correct fittings just a little different size. My guess is that the part I have is meant for an 06Z. I could just cut the wires...
Old Nov 24, 2009 | 02:53 PM
calin's Avatar
calin
My car is an '06 and came with that antenna from factory. Maybe it's like you said, it could be that they changed the fittings in 06 since they changed a lot of other things with the car.
Old Nov 24, 2009 | 02:58 PM
Bilz's Avatar
Bilz
Probably. I doubt there's a adapter...have you taken a look at your sat reciever?
Old Nov 24, 2009 | 03:01 PM
calin's Avatar
calin
No, sorry. I've never even used my sat radio. I just have it, but it's not activated since I always listen to cd's.
Old Nov 24, 2009 | 03:07 PM
Bilz's Avatar
Bilz
Are the terminals for the antenna yellow and green?
Old Nov 24, 2009 | 03:10 PM
calin's Avatar
calin
I've never taken my stereo or antenna out so I'm not sure, sorry.
Old Dec 1, 2009 | 12:17 PM
Forever Z's Avatar
Forever Z
You need part # 28243-CF40B. It's the extension wire that goes from the oem antenna to the oem sat receiver. I have sirius though, I'll check to see if they're the same.
Old Dec 1, 2009 | 12:22 PM
Forever Z's Avatar
Forever Z
Yeah, it should be the same.
Old Dec 1, 2009 | 02:08 PM
Spike100's Avatar
Spike100
Nooo! You must not cut the antenna wire. Doing so will disable reception, and you cannot fix this without running a new wire.
The antenna piece for satellite receivers are interchangeable The fix is finding the correct adapter to connect the wire to your brand of satellite receiver. It looks as though Forever Z has a part number for you.
--Spike
reno56
Interior
17
Nov 20, 2015 05:21 PM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
Mikey Likes It
Audio Builds
Feb 25, 2003 03:44 PM
