Screen with 2 video inputs (cubby)
Old Nov 24, 2009 | 11:48 PM
greenbeauty's Avatar
greenbeauty
Default Screen with 2 video inputs (cubby)
I own a 2004 350Z.
I'm looking for a screen (normal, not touchscreen) with 2 video inputs.
I want to connect a rear view camera, and as a second screen for my HU.
The farenheit T-7001MHR is one possibility..
But I have read on this forum that this screen has a poor quality for navigation.
What are the other possibilitys for a screen with 2 inputs?
Maybe Xenarc? but they don't fit very well, and I don't want a touchscreen.
EDIT:
I Just read that it's more handy to buy a farenheit t7001mhr and use a a/v switch to control it manually,
so you don't have to use a remote..
What is this for a/v switch device? and where can I buy it?
Thanks!
Old Nov 25, 2009 | 05:28 AM
Z_Youlater's Avatar
Z_Youlater
check out ConceptZperformance.com hope that'll help you out.
Old Nov 25, 2009 | 09:33 AM
greenbeauty
Yes but do you have some answers for me in my post?
Old Nov 25, 2009 | 02:19 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
If you can't find a two input screen fine a tiny toggle switch to take care of your input expansion.
Old Nov 25, 2009 | 06:30 PM
Spike100's Avatar
Spike100
You definitely do not want the Farenheit T-7001MHR. This monitor does support toggling between two different video inputs, but the device has significant disadvantages:
  • The Farenheit T-7001MHR is built cheaply with a lousy case/enclosure. To fit this to your Z, you have to cut a cheap headrest mount, and even with this done the monitor’s electronics are poorly protected.
  • The Farenheit T-7001MHR displays its image poorly with exaggerated colors and contrast.
  • The interface is overly complicated and confusing
  • You toggle between the video sources using the handheld remote control. That means that every time you switch video sources (maybe a GPS and a rearview camera), you must dig-out the remote and press the right switch. If you are driving, you don’t want to do this.
A much better choice is the Farenheit T-7000MHR (this LCD is also sold as Power Acoustik PT-700MHR or NESA Vision NSM-7005 7" monitor). These devices have a better enclosure and provide a better image.
As Paul350Z mentions:
Originally Posted by Paul350Z
If you can't find a two input screen fine (find) a tiny toggle switch to take care of your input expansion.
All you need to do is install an A/B switch (to toggle between 2 video sources… maybe a GPS and rearview camera) or an A/B/C switch to change from one to three devices.
Paul posted a thread (now a few years old, but constantly updated by my350z.com members) that will never die. Reading your post, I’m guessing you read this thread. I just added some information to his great thread. See this message to see a good way to connect and power your 7” LCD monitor:
https://my350z.com/forum/7946037-post168.html
Sorry for the long post. I need to figure out how to provide information without so much detail and length.
--Spike
Old Nov 25, 2009 | 10:38 PM
greenbeauty
@spike, thanks!
Is this switch will do the things I want?
http://cgi.ebay.com/ws/eBayISAPI.dll...:X:RTQ:US:1123
And do you have a internetlink for me with a switch that you use??
I'm gonna buy the 7000mhr
Old Nov 27, 2009 | 01:14 PM
Spike100's Avatar
Spike100
^^ I think that should work (but I've never used the device you linked). It might be overkill if you are just connecting a couple of input devices to a single screen.
You might want to check with crutchfield.com. They have a good support staff that can help you select the part you need.
I built my own video switch using parts from my "electonics graveyard."
--Spike
etkms
Jun 19, 2022 06:30 PM
Workshop12
Mar 23, 2020 01:45 PM
Justin100
Nov 29, 2015 03:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
