Cheaper 7" VGA touchscreen
Old Dec 8, 2003 | 12:50 PM
  #61
murrman100's Avatar
murrman100
Post away.
Its always cool to see what other Z lovers have done.
Old Dec 8, 2003 | 05:05 PM
  #62
ECKZLNT's Avatar
ECKZLNT
sorry about the quality of the pictures, or the lack there of
here's the front of the case cut up and being glued in place
Old Dec 8, 2003 | 05:08 PM
  #63
ECKZLNT's Avatar
ECKZLNT
and then with the case modified and screwed back together, notice the flat wire coming out of the bottom is where the button board plugs in..and the usb connecter that sticks out so far on the right
Old Dec 8, 2003 | 05:09 PM
  #64
ECKZLNT's Avatar
ECKZLNT
and here's how it looks in place
I don't have any installed yet, and my car is still snowed in so more on that later
Old Dec 8, 2003 | 08:15 PM
  #65
murrman100's Avatar
murrman100
Dude!
You don't have to connect the usb connect to the monitor unless you have a usb device, like a joystick, keyboard or mouse coming from the monitor.
The usb from the output to the computer is the only usb connection that you need.
Its just a bypass to another usb device. The touch screen will work with out it.
Old Dec 8, 2003 | 08:17 PM
  #66
murrman100's Avatar
murrman100
I knew that they made those binder clips for a reason. LOL
Old Dec 9, 2003 | 03:55 AM
  #67
ECKZLNT's Avatar
ECKZLNT
No, that USB connector is for the video and audio in, So I needed it to connect it to the video out from my HU. The VGA and touchscreen USB outs come out of the back, I wish they all did
Old Dec 9, 2003 | 07:58 AM
  #68
ZZZealous007's Avatar
ZZZealous007
hey ECKZLNT,
Post sum pics of the install!!
What is the NTSC/PAL adapter plug which is usb? What is that used for? I thought the Lilliputs have those three wires(yellow red white) for sound and audio. PLease elaborate. A pic of this may help. Im still a newb when it comes the new VGA screens.
Also, did this screen replace the stock navi? or is this replacing the storage compartment?
ARe you just extending the stock IR receiver which comes with the Screen? OR are you putting on an aftermarket IR receiver which connects to your serial port?
AS for you PSU, what kind are you using? Maybe someone here can help u. post ur computer specs as well.
murrman100:
Try using a zip tie going lengthwise over the cable plug. That should keep the cable in its place. Im not sure how u set ur box up but it sounds like the harddrive isnt secured down. If its not the bumps in the road may be making the disk and reader head to skip. Therefore crashing your comp. The insdustrial velcro u can get from Home Depot may help with that.
Old Dec 9, 2003 | 10:44 AM
  #69
ECKZLNT's Avatar
ECKZLNT
Yes, it does have the yellow/red/white cables, but they connect to the screen with a USB plug. The screen comes with a remote, but the sensor is right below the screen where the buttons normally are. So in order for the sensor to see the remote, I had to make it visible. I don't have the stock navigation, I put it where the stock screen would go. I will take/post pics tonight when I get home.
Old Dec 9, 2003 | 10:49 AM
  #70
uklooney's Avatar
uklooney
Would this help?
Old Dec 9, 2003 | 10:57 AM
  #71
ZZZealous007
i think it would help if your up for a little soldering
Old Dec 9, 2003 | 11:01 AM
  #72
uklooney's Avatar
uklooney
Or if you have a little space...
  #73
ECKZLNT's Avatar
ECKZLNT
Yeah, I found them when I searched to see if any right angle adapters existed. I didn't want to wait anymore, and wanted my car back together. Who knew I would only be able to drive it for a day and a half before it rained/snowed. Now I just want it to rain already to wash this salt away
Old Dec 11, 2003 | 01:33 PM
  #74
Grommit's Avatar
Grommit
Wow, that looks really good.
What kind of glue did you use? Can't wait to see more pictures and I can't wait to do this mod myself!
Old Dec 11, 2003 | 02:09 PM
  #75
ECKZLNT's Avatar
ECKZLNT
well, this is what it looks like with the screen on, sorry that the pic sucks, I can't take pictures
Old Dec 11, 2003 | 02:12 PM
  #76
ECKZLNT's Avatar
ECKZLNT
this is all I had in the house at the time
  #77
ECKZLNT's Avatar
ECKZLNT
and here's the picture of the glue
Old Dec 11, 2003 | 03:29 PM
  #78
Grommit's Avatar
Grommit
Good job! That looks totally clean. What did you end up doing with the button panel for the flat screen? Also, can you post a close up shot of the screen? Thanks bro!
Old Dec 11, 2003 | 05:38 PM
  #79
ECKZLNT's Avatar
ECKZLNT
Well, the button panel is kinda just hanging behind the screen. I just ran the remote sensor down to the right of the V1 display, on top of the center speaker/below the head unit. I just use the remote for now.
I'll post a close up shot when I get a chance to take a good one, possibly in daylight (damn work).
Old Dec 12, 2003 | 07:42 AM
  #80
ZZZealous007
ECKZLNT: Sweet remote V1 install! I didnt even notice it the pic until you mentioned it. I know this is a little off topic but, i just wanted to know where you mounted your radar?
Something more on topic regarding the screen:
Now that you guys have your screen all set up and ready to go. Have you thought about making a custom interface program for the Z so you have easy access to DVD/ NAV/ MP3...or anything else you may have? Any programmers?
