Help.. Focal = failed
Old Feb 27, 2010 | 11:44 AM
ss350's Avatar
ss350
Default Help.. Focal = failed
Hey Guys,
I have a set of focal 165kp components up front. Recently one of the midrange speakers failed. The wire from the lead terminal to the voice coil was severed. I am quite diasspointed after what I payed for these things.
So Im stuck with perfectly good 2 tweeters, 2 components, and 1 midrange. What do you think my best option is? Can I just replace the midrange speakers with a different brand or model? If i buy a new set of components, can I use the focal tweeters and crossovers (the tweeters are installed in the factory location witch I have drilled out)? What do you think?
thanks
Old Feb 27, 2010 | 12:19 PM
TomCat0197's Avatar
TomCat0197
You could try contacting Focal to purchase just the 1 midrange. Boston Acoustics used to sell the speakers individually. I would not buy just any speaker to hook up to the crossover.
Old Feb 27, 2010 | 01:02 PM
duro78's Avatar
duro78
How old are they(warranty)? check around to see if there's a local speaker repair shop. If you feel competent thats actually an easy fix
http://parts-express.com/
Old Feb 27, 2010 | 01:14 PM
3-fifty-WeEe's Avatar
3-fifty-WeEe
yumyum puppy bum
Old Feb 27, 2010 | 01:17 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Reattaching the wire to the voicecoil is not that big of a deal
I'd also take the time to figure out why it severed. Vibration? Poor solder joint? Overextension of the driver?
Old Feb 27, 2010 | 02:31 PM
Spike100's Avatar
Spike100
^^ Yes, it's easily repaired. I also agree that it's wise to determine the cause of the failure so it doesn't happen a second time.
--Spike
Old Feb 27, 2010 | 06:30 PM
SatchScream's Avatar
SatchScream
You can't just try to re-wire it?
Old Feb 27, 2010 | 09:00 PM
davidc81's Avatar
davidc81
if unrepairable and you cant find a replacement mid, i would buy a separate set of mids and run them active with the tweeters you already have. i damaged a mid on my focal 136k components back in the day and that's what i ended up doing.
Old Feb 28, 2010 | 05:56 PM
ss350's Avatar
ss350
I had them for a few years now. I dont know what kind of warranty they come with, but I'm waiting to hear back from Focal.
I think the adhesive that holds the lead wire to the speaker cone failed. This allowed the vibrating speaker cone to eventually break the thin voil coil wire. I tried to solder to the wires together, but I couldnt. The voice coil wire severed right next to the spider. There was less than a millimeter of wire to work with. I tried to expose more wire by cutting a small hole in the spider, but the voice coil wire was covered and could not be accessed. I honestly don't think I can solder the wires without destroying the speaker.
If I cant get a replacement from Focal, I guess I'm going to have to find some midrange speakers and replace both sides. Anyone know where I can find some quality midranges without the tweeters and crossovers?
thanks
Old Feb 28, 2010 | 06:30 PM
davidc81's Avatar
davidc81
you can order raw drivers from focal but they'll be expensive. you could also try seas or morel. if you're on a budget, elemental designs 6500 mids are pretty good for the price.
350z_z33.
Jul 3, 2017 04:01 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
h8redlights
Sep 11, 2015 07:57 PM
03 Z for ME
Cleaning & Detailing
May 10, 2003 07:37 PM
KJ-350
Mar 9, 2003 04:46 PM
