So how and where do you guys mount a rear usb cable
Old Apr 5, 2010 | 02:38 PM
psytropic's Avatar
psytropic
Default So how and where do you guys mount a rear usb cable
I'm thinking of getting a head unit with a USB cable that runs out the rear of the unit. I was wondering what was the popular way to run it into the cubby hole or a place I can get to it.
Old Apr 5, 2010 | 02:39 PM
Waiz's Avatar
Waiz
I actually drilled a small hole in the corner of the cubby and ran it through there to connect to my ipod.
Old Apr 5, 2010 | 04:14 PM
Spike100's Avatar
Spike100
Same here... I drilled a hole in the right rear corner of the cubby, installed a rubber grommet (to prevent the wire from slipping or getting scraped), and ran the wire through the grommet.
I had to cut the grommet through its radius since I was unable to thread the USB connector through the grommet. I positioned the wire inside the grommet, and then pushed the grommet to place.
The arrangement looks great, prevents noise entering from behind the dash, and holds the wire so it does not slip or scrape against hard plastic.
--Spike
Old Apr 5, 2010 | 04:23 PM
DavesZ#3's Avatar
DavesZ#3
Yeap, hole in the back corner of the cubby is the way to go.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
