Any issues with Pioneer 4200DVD head unit?
Old Apr 19, 2010 | 12:07 PM
yomike007's Avatar
yomike007
Bypass was extremely easy.
http://www.youtube.com/watch?v=g8HCcNy9QQQ
Careful, as the pin numbers on the bypass given in this video might not match up to yours.
I used a 4-pin automotive relay from autozone. This one to be specific:
http://www.autozone.com/autozone/cat...lot+Automotive
Simply connect pins 30 and 85 to ground. Connect pin 87 to your green remote turn on wire from the head unit. Connect pin 88 to the remote amp turn on coming also from the head unit. DONE!
Connect pins 30 and 85 to an actual ground point on the car. I tried to connect it to the black and white 'ground' wire with no luck.
Old Apr 19, 2010 | 12:11 PM
yomike007's Avatar
yomike007
And heres a GREAT link on how to burn divx files to work on your player...
http://www.avic411.com/forum/viewtop...highlight=divx
Old Apr 19, 2010 | 12:15 PM
yomike007's Avatar
yomike007
Also, dont pay $50 for the pioneer ipod/iphone cable. Here is one for $3
http://www.monoprice.com/products/pr...seq=1&format=2
This will allow your phone to play audio, and charge the phone.
There is adifferent cable that allows you to play audio and video, but not charge the phone.
Old Apr 19, 2010 | 06:00 PM
platinum350's Avatar
platinum350
Awesome, looking forward to the pics and getting mine!
Old Apr 20, 2010 | 05:53 PM
JMSpeed's Avatar
JMSpeed
serial is broken, but any one of the many converter programs out there should work using the same profile.
Old Apr 21, 2010 | 07:39 AM
Zzman916's Avatar
Zzman916
any pics of where to dremel?
Old Apr 21, 2010 | 01:08 PM
afwiggith's Avatar
afwiggith
Thanks mike, and that's the bypass that you don't have to do any "pull the parking brake and then let it off again" one? It just plays video whenever after that?
Old Apr 21, 2010 | 06:10 PM
JMSpeed's Avatar
JMSpeed
PAC-TR7
it's always on and wires up to be hidden away. no switch needed.
Old Apr 22, 2010 | 04:41 AM
afwiggith's Avatar
afwiggith
Alright, now I just need another dash kit and I can finish the install correctly. Normally, I like to do things right the first time, but I was having a REALLY bad day when I installed this and just had to go for a drive and listen to my metal, so rushed the job a bit.
Old Apr 23, 2010 | 06:32 AM
JMSpeed's Avatar
JMSpeed
you can try American International dash kits. Check this post for the installed look: https://my350z.com/forum/audio-and-v...installed.html
Finding one from a reputable retailer was difficult and their reps spend little time suggesting locations near you. I just ordered mine off eBay: http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
Old Apr 23, 2010 | 08:31 AM
Iceman007's Avatar
Iceman007
hEY guys, got mine all finished up, although had to get sum help due to having the stock nav, it kinda made things tricky, basically I dont have the voice direction now. Which I dont really use that much anyways, so its all good! Love the HU, cool custom background and color options! There is an orange setting if you want to match the stock dial colors. Unfortunately dont have a camera myself, but did take some with my iphone, hope it is clear enough for ya to see!
Old Apr 23, 2010 | 08:34 AM
Iceman007's Avatar
Iceman007
Oh one other thing, be very careful when ordering the ipod adapter online! The first one I ordered which was a great price ended up not being long enough, so had to send back and get a longer one. Just a fyi on that, you want to make sure its long enough to reach into your cubby center console.
Old Apr 26, 2010 | 03:20 AM
JMSpeed's Avatar
JMSpeed
where are pics?
Old Apr 26, 2010 | 07:49 PM
Zzman916's Avatar
Zzman916
just installed the p4200dvd, and I'm not getting signal from the radio stations. I checked to make sure the antenna plug is plugged in, and it is. I notice that there is a blue power antenna wire on the harness, is this suppose to be hooked up? if so, to which wire? help please
Old Apr 27, 2010 | 03:10 PM
Zzman916's Avatar
Zzman916
Can't seem to play video files from my hard drive or sd card. They are in avi format. Any ideas?
Old Apr 28, 2010 | 04:08 PM
JMSpeed's Avatar
JMSpeed
you're having all sorts of problems on features that should work...
what size hard drive and what class sd card?
Old Apr 28, 2010 | 04:25 PM
krass's Avatar
krass
Thanks for the info... This should work on a AVH-P3200DVD as well, correct?
Old Apr 28, 2010 | 04:58 PM
  #38
Zzman916's Avatar
Zzman916
I fixed the radio reception and got the sd card to read my videos fine. The unit just won't read my Western Digital 80gb Hard drive. Guess I need to find another hard drive
Old Apr 29, 2010 | 05:11 PM
  #39
JMSpeed's Avatar
JMSpeed
Good to hear. What class SD and what size? Some were saying class 6 sdhc cards would not work, while the class 2 did.
Also, I've read that a USB-powered drive wont work over 250GB. That was my concern with yours. How long are you waiting for it to read the files? Maybe the load time is just ridiculous... Makes me worry about whether getting a 250GB hard drive was worth it if it won't work anyway.
Old Apr 29, 2010 | 05:28 PM
  #40
Zzman916's Avatar
Zzman916
I had a 8gb class 6 SD card, I had to convert my video files using the DivX tool and it read on the unit fine. For the hard drive, I waited a good 5 mins and all the screen would say was something like "incompatible format" or something to that extent (forgot what it said). But the weird thing is, I had the Pioneer 690ub unit before I installed the p4200dvd and it read the audio files on my hard drive fine. So I'm kind of stumped.
