installed new hu now reception is horrible
Old Jun 20, 2010 | 08:40 PM
w210e55's Avatar
w210e55
Default installed new hu now reception is horrible
Hey Guys,
I already searched and found that I need to hook the power antenna lead from my HU to the solid blue wire coming from my wire adapter for the antenna amplifier to work. I did that and still have horrible reception. Any suggestions?
thanks
Old Jun 20, 2010 | 11:46 PM
hellsoldiers08's Avatar
hellsoldiers08
you made need a booster for the fm/am signal. that what custom sounds told me.
Old Jun 21, 2010 | 03:28 AM
SamSpicer's Avatar
SamSpicer
I have the same problem
Old Jun 21, 2010 | 05:30 AM
w210e55's Avatar
w210e55
Default fixed!
I had a brain storm last night and remembered that I disconnected a green white plug that was connected to the antenna when I disconnected my stock bose HU and didn't plug it back in when I installed my new HU. I plugged it back in, connected power antenna from my HU to the solid blue wire on my radio adapter and VIOLA, reception is back to 100%.
Old Jun 21, 2010 | 10:37 AM
ZPHILE's Avatar
ZPHILE
THAT'S IT! I've gone through the same issue. Your little funny antenna has an amp that needs to be powered in order to amp those RF signals. All the others on this thread probably have the same issue!
Old Jun 21, 2010 | 10:40 AM
ZPHILE's Avatar
ZPHILE
NO! The Z has a stock antenna amp that needs to be powered by the H/U. The stock unit does it normally. When you upgrade you need to connect this to your non-stock H/U's antenna power source. For my Kenwood it was the power antenna wire.
Old Aug 16, 2012 | 07:04 PM
coanan's Avatar
coanan
reviving, where is or what color is the ant amp wire?
Old Aug 17, 2012 | 03:14 AM
122554's Avatar
122554
^ +1
Old Aug 18, 2012 | 07:03 PM
patrickoneal's Avatar
patrickoneal
I had the same issue when I installed my aftermarket head unit, no reception. I ended up finding out about the antenna amp as well. I don't remember what color it is, but if you're using a wiring harness kit, it should be marked. It's either blue or blue and white if I remember correctly.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
