backup camera, new option...
Old Oct 3, 2011 | 04:54 AM
  #201
Bomb0314's Avatar
Bomb0314
I'm looking to spend $20 - $30 on a backup camera, any recommendations?
It's just more of an thing I want to add in for fun...
Old Oct 3, 2011 | 08:37 AM
  #202
DavesZ#3's Avatar
DavesZ#3
How about the one that's the subject of this thread? One of the cheapest I've seen so far.
Old Oct 3, 2011 | 06:13 PM
  #203
Bomb0314's Avatar
Bomb0314
the pics on the first page don't work... how is the ETO Rear View Camera? *first link in OP*
Old Oct 4, 2011 | 03:20 AM
  #204
DavesZ#3's Avatar
DavesZ#3
Some of the other pics in the thread are from that module. I've been very happy with mine. In the dark, the picture is a little grainy, more so than the $150 Audiovox backup camera I had at first. The addition of the guidelines makes it worth it though.
Old Oct 4, 2011 | 06:57 AM
  #205
06blueZ's Avatar
06blueZ
Fixed the pics in the OP, sorry didn't notice they were broken...
over year of use, and still working great. really happy with it!
Old Oct 4, 2011 | 04:46 PM
  #206
Bomb0314's Avatar
Bomb0314
thanks guys. I ordered it yday night and skimmed the thread...
My plan is to power the camera via the reverse light and also use the reverse light to send the single to my double din.
Old Oct 17, 2011 | 03:19 PM
  #207
Bomb0314's Avatar
Bomb0314
so just a little update... my package came in today. got tests and job interviews this week, so can't install the camera till later on this weekend or next week.
do I have to take off the bumper to install or can I install without removing the bumper? also to ground the camera did y'all ground to chaise?
Old Oct 17, 2011 | 03:36 PM
  #208
DavesZ#3's Avatar
DavesZ#3
I did not remove the bumper. You do have to remove the license plate and the interior panel. You can work the wire through the rubber grommet behind the plate through to the rear hatch. I grounded to a bolt on the back side of the rear hatch under the removed panels.
Old Oct 23, 2011 | 05:19 PM
  #209
Bomb0314's Avatar
Bomb0314
so just tried to install the camera... got it wired up and seems like I got a dead camera.
Had the reverse signal to headunit and power connected to same source in the back of car... checked and rechecked the input signal on headunit. I'll get the headunit to switch to rear view camera mode but all I see is black, no input from camera.
sent the ebay seller a message asking for an exchange. sucks that I have the car all taken apart.
Old Nov 4, 2011 | 09:58 AM
  #210
Bomb0314's Avatar
Bomb0314
Update: Seller contacted me fairly quickly and worked it out where I paid him an extra $10 and he shipped me a new camera. Wired it up and works great! - guess the first one I got was bad or something. For anyone thinking to buy a rear view camera, I'd say for the ~$35 its worth it!
Couple pics:
Old Jan 18, 2012 | 01:51 PM
  #211
mvallejo's Avatar
mvallejo
Default Cant get this thing to work!!!
Has anyone had a problem with the rearview camera and the Magellan 1700??
I bought the CCD rear view camera and the Magellan 1700, wired everything but when I put the car in reverse nothing happens. it is like the magellan does not even recognize that there is a cable plugged in. I am using the RCA video cable that came with the camera.
Any thoughts on what could be happening.
Just in case, I wired the camera to the light green wire in the trunk.
Old Feb 11, 2012 | 08:47 AM
  #212
Ryfi's Avatar
Ryfi
are 2003 and 2006 350z cameras the same ?
Old Feb 11, 2012 | 09:22 AM
  #213
Linuxglobal's Avatar
Linuxglobal
03-08 use the same plate lights, signals, tails (shape) so they will all fit.
The camera you pick will have to work with your headunit.
Cheers
C
Old Feb 11, 2012 | 09:24 AM
  #214
Linuxglobal
I would use a voltemeter to see if the camera is actually getting power from the light green wire in the trunk.
The magellan will need a 12v line to signal that its getting a reverse input, thats how must hu know to turn on the rear view camera input.
You can also try connecting your camera to another input just to test that is working when the car is in reverse.
Old May 26, 2012 | 10:00 PM
  #215
coops808's Avatar
coops808
Hey, looking to get the CCD camera from here:
http://www.ebay.com/itm/Nissan-350Z-...ht_6682wt_1163
However, I already have the OEM navigation system, and I don't want to install an aftermarket head-unit, as having 2 screens will look odd.
Does anyone know if it is possible to hook up this or another back-up camera to the OEM navigation system screen?
Thanks!
Old May 27, 2012 | 06:10 AM
  #216
dkmesa350z's Avatar
dkmesa350z
Thanks!
http://kptechnologies.com/products.p...san&model=350Z
I believe the navigation 'OK' bypass adds an auxilary video input.
Old May 27, 2012 | 12:09 PM
  #217
coops808's Avatar
coops808
Thanks for the info!
Old Jul 24, 2012 | 08:29 PM
  #218
dmorrow's Avatar
dmorrow
okay. ive read through plenty pages. and just confused. i want to make sure to do this right. so please, spare me, and someone help me with what i have.
Magellan 7" gps. this back up camera.
you take the wire from the camera, and feed it through the license plate area. got that.
now, ..what?
how do i go from that little camera having that one plug to wiring it to my gps to turn on when i put it in reverse????
im guessing ill need extra wire? or do i need to wire this camera wire into one of the reverse light wires? how then will the gps pick that up automatically???
Old Jul 25, 2012 | 06:45 AM
  #219
Voboy's Avatar
Voboy
How is this backup camera lasting after a year or two? I bought an Audiovox from some other threads recommendation and it has died after having condensation build up stuck in between the lenses.
Old Jul 25, 2012 | 08:36 AM
  #220
dkmesa350z's Avatar
dkmesa350z
my CCD has held up well. No issues.
