Mounting amp under/behind glove box?
Old Nov 13, 2003 | 10:56 AM
AndyB's Avatar
AndyB
Default Mounting amp under/behind glove box?
Has anyone mounted an amp (say 4X50) under or behind the stock glovebox (behind passenger).
I would like to keep the glove box (since this is a roadster and it barely has any cargo room to start with.
I could have sworn someone did this, but I can't find it in a search.
If you have seen this done or done it yourself can you post some info or even pics?
I know the glovebox comes out easily. I am just wondering how much space is back there under/behind it.
What size amp will fit?
How much room is there?
Old Nov 13, 2003 | 01:15 PM
Frisco's Avatar
Frisco
Look at my thread here about amps in the stock sub location. There is a really nice one in there that used some 3/8" wood and some 1/2" aluminum rails.
https://my350z.com/forum/showthread....threadid=49140
Ooops my bad, I think you're talking about a different area than that.
Old Nov 13, 2003 | 07:40 PM
alphared's Avatar
alphared
you can mount it there. Theres about 1.5" - 2" clearance. BUT you gonna lose the secret storage bin. What I did was mount it behind the glove box, at an angle. You'll never see it if you lift the secret storage bin up and makes it extra hard for thieves to steal it. (but makes it hard to adjust gain or change fuses).
Old Nov 14, 2003 | 05:32 AM
onecoolee's Avatar
onecoolee
My secret storage area became my Audio Control EQ's headquarters...
Attached Thumbnails Mounting amp under/behind glove box?-glovebox1.jpg
Old Nov 14, 2003 | 06:02 AM
AndyB's Avatar
AndyB
Default Behind
Sounds good to me.
I am hoping that once it is dialed in I never need to see it again. I am not running a ton of power or anything exotic, so fuse changes should be 0 once the installation is done.
You don't have any pics of mounting it behind the glove box do tou?
Or maybe an estimate of how much room is there?
What size amp did you fit behind the box?
Thanks inadvance.
AndyB
Old Nov 14, 2003 | 08:14 AM
Norel350Z's Avatar
Norel350Z
Mine is under the floor of the glove box, fits fine.. im using a JL 250/1 not sure the size specs, but it fits good, a little tight, but not to bad, im thiking about moving it, just waiting for the damn wind to go away, and some warm weather to show up
Old Nov 14, 2003 | 09:26 AM
AndyB's Avatar
AndyB
Default wind
Yeah, the wind and cold is getting a little old. (I am in coastal CT)
Why would you move it if it fits and is working? (just curious)
Old Nov 14, 2003 | 10:44 AM
alphared's Avatar
alphared
i might be able to take a pic this weekend. it's a mtx thunder 5 ch amp, not sure bout the size (10x14x3, guessing)
I wanted to mount it under the glove box, but with the secret compart in, there's only about 1.5" - 2" of space.
Old Nov 14, 2003 | 05:59 PM
Norel350Z's Avatar
Norel350Z
I donno, just wanted something a little neeter, my OCD i guess, its not one of my major concerns right now, but its on the 'thing to do list'
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
