behind the seat sub
Old Nov 2, 2010 | 12:43 PM
yahmeboys's Avatar
yahmeboys
Default behind the seat sub
whats up people. i'm planning on building a custom sub enclosure for the compartment behind the passenager seat.
I was interested if anyone has successfully built a enclosure to go in this compartment.
want to see if there are things i havent thought of yet so tell me your experiences or just give some ideas you may have to help me
Old Nov 2, 2010 | 01:14 PM
kevincat's Avatar
kevincat
or pay 100 bucks for this
http://cgi.ebay.com/Nissan-350z-Coup...item3a5ccba9ef
Old Nov 2, 2010 | 01:25 PM
yahmeboys's Avatar
yahmeboys
you have to be kidding me. I've been looking for the past couple weeks if anyone built these boxes and i could freaking find anybody. I came to the concusion nobody did them so i told myself i have to build it myself but i dont have to anymore. thanks i really appreciate it
Old Nov 2, 2010 | 01:35 PM
kevincat's Avatar
kevincat
i think wickedcas sell a similar one for 370 dollars. and those have been out for quite a while now. i think these are a cheaper alternative.
Old Nov 2, 2010 | 06:55 PM
Spike100's Avatar
Spike100
Hi, Your question has been discussed many times here on my350z.com. You can purchase a prefabricated SubW enclosure that fits behind the Z’s driver or passenger seat. You can also purchase the enclosure loaded with a SubW from at least one vendor on my350z.com.
There are also detailed diagrams with complete measurements for building a SubW enclosure if you want to do this yourself.
--Spike
Old Nov 10, 2010 | 06:26 PM
ledit0ut's Avatar
ledit0ut
Originally Posted by kevincat
This is only 5.25" deep? Does anybody have any recommendations for 8",10" subs that would fit in there? Thanks.
I'm a noob!
Old Nov 10, 2010 | 06:51 PM
dcains's Avatar
dcains
Here's mine:
The finished install uses the the OEM Bose metal plate and plastic trim panel, so it looks 100% stock. The sub amp is inside the glovebox (pictured), and the other 4-ch. amp is under the glovebox. Main speakers are Boston separates, deck is a Kenwood touchscreen (can't remember the model #).
Old Nov 10, 2010 | 07:13 PM
dcains's Avatar
dcains
Forgot the dimensions of the box, and I know you'll ask. It's 18.5" left-to-right, 12.5" front-to-back, 6.5" high, glued and screwed 3/4" MDF. Sub is 10", interior volume is just under 0.6 cu. ft. and my sub required 0.65, so I added 1/2 pound of fiberfill. With a plain rectangle, that's the biggest possible box that area will accept, but volume could be increased if one wanted to construct a trapezoid, or other odd shape.
Old Nov 15, 2010 | 08:23 AM
iheartmyz's Avatar
iheartmyz
anyone know how good the sound quality is on these bad boys?
Old Nov 15, 2010 | 09:36 PM
dcains's Avatar
dcains
I wonder how it sounds without a speaker grille? If you use it to replace your glovebox (passenger side), and you had a Bose sub you removed on the other side, I guess you'd be OK. But, if you mounted it to replace the Bose sub (driver side), then there isn't any way to have a speaker grille to let the sound pressure out.
Old Nov 16, 2010 | 02:21 PM
iheartmyz's Avatar
iheartmyz
essacly my point
Old Nov 18, 2010 | 07:13 PM
NDmoney's Avatar
NDmoney
I bought 1 Wickedcas JL 13.5 sub to put in the stock bose location... not for me, I blew it by listening to the only type of music subs need apply... I got 2 of their JL 10w3 subs and replaced the factory bose loc and glove box. The bose grill is really an astetic piece.. it looks good but for the downfiring application of these subs there is no diff... but putting a Rockford Fosgate 1000d.1 amp a 1 farad cap and new door/sail panel speakes as well as coustom kicks with 6 3/4" Polk audio/MOMO components powered by an MTX amp sending 75 watts RMS to the highs/mids per side and 500 watts RMS to each sub... it knocks with no space taken up at all.....
Old Nov 19, 2010 | 07:46 PM
yahmeboys's Avatar
yahmeboys
ok so what do you guys think.... should i try that ebay enclosure or dont waste my money
Old Nov 19, 2010 | 11:37 PM
dcains's Avatar
dcains
I can only tell you the custom box I made with the 10" JL sub sounds pretty good (the other 4 speakers are Boston separates). Cost for the MDF, screws, caulking, FatMat, etc, was only ~$50. I was trying for an accurate sound, only loud enough to listen to inside the car, and it does that very well. if you're looking for something to rattle the rear hatch, this isn't going to work for you.
Old Nov 27, 2010 | 09:29 AM
stevez redline's Avatar
stevez redline
so what about just buying an aftermarket universal box and sliding it in the factory sub location
Old Nov 27, 2010 | 10:05 AM
dcains's Avatar
dcains
Getting the most volume in a box that has to fit such a small space is the problem. I would have bought a pre-made box, but couldn't find one to fit. The dimensions of mine are the most you can get into that opening,
NiLL
Nov 29, 2021 02:26 PM
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
AngryZ
East Canada
Sep 16, 2015 05:08 PM
