Mirror Power Wire installation for radar detector
Old Jun 19, 2011 | 05:26 PM
davide's Avatar
davide
Default Mirror Power Wire installation for radar detector
I bought a fused wire setupmto power my BEL from my mirror. I went to install itmtoday and while it works right, I couldn't get the wires to stay in the power connector to the mirror. They either wouldn't go in and got bent up or they went in and promptly fell out. Any suggestions???
Old Jun 19, 2011 | 05:33 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Why not solder the wires or tap the existing wires?
Old Jun 19, 2011 | 05:52 PM
davide's Avatar
davide
Shouldn't have to.
Old Jun 19, 2011 | 07:04 PM
shakuya88's Avatar
shakuya88
"Shouldn't have to" just means there is more than one way. Only one can be the "best" way 3hree5ive0ero just told you the best way. One thing I've learned, most of the people who have been around longer...known more
Old Jun 19, 2011 | 07:56 PM
SparkleCityHop's Avatar
SparkleCityHop
Living in 350Z
The stealth wires come with a small zip tie that you're supposed to use to keep them in place and connected to the back of the mirror. It sounds like you may not have used the zip tie to secure them in place?
However, as mentioned, soldering is the best way to make sure that it will stay in place and maintain a reliable connection.
Old Jun 20, 2011 | 02:01 PM
bmccann101's Avatar
bmccann101
i started looking into this after your post this morning.. i see what you mean, theres like probe taps for those deals.. actually pretty damn cool.
My solution would be to put a dab of good ol super glue on them after theyre plugged in well and you verify power.
Reason i say super glue is that its thin, strong in small quantities, and you can easily give it a twist and get it out if you every reeeally have to remove it..
Old Jun 20, 2011 | 03:41 PM
3hree5ive0ero
Retired Admin
I'm not sure I'd use super glue (which eats away at plastic). They do have spray adhesives or something for electrical wires, though.
350Z_Al
Oct 29, 2020 07:44 PM
