Aftermarket Radio w/ Nav and Bose Help!
Old Jun 22, 2011 | 06:55 PM
stikystikyricky's Avatar
stikystikyricky
Default Aftermarket Radio w/ Nav and Bose Help!
Hey, so I just picked up a 350z on ebay. It has a kenwood double din headunit and nav. It also has a bose system. It sounds like trash!!
Only the front speakers work and I cant get the rears to work.
I pulled the cover off of the sub and it still has the rear speakers and bose sub installed as well as front bose speakers.
I thought you couldnt wire an aftermarket unit to bose speakers??
Does anyone know how the previous owner might have gone about doing this and what my options are? Only the front speakers work and there is absolutely no bid bass or low end. Do I have to gut the entire system and re-wire everything?
Thanks
Old Jun 22, 2011 | 10:31 PM
BlkdOutZ's Avatar
BlkdOutZ
I have all my bose speakers minus the sub hooked up to a pioneer deck so I know it is possible. I couldnt tell you anything about your problem without seeing it tho, You might just want to take it to a good audio shop to see what they have to say if you dont know about car stereos yourself.
Old Jun 23, 2011 | 10:02 AM
LVZ053's Avatar
LVZ053
I believe you need a PAC-OEM adapter when installing a non bose head unit to bose speakers. I had to get one for it to work and my speakers sound normal.
Old Jun 23, 2011 | 10:13 AM
bonarsauce's Avatar
bonarsauce
^ This is correct you need the amp integrator the model is isve61 made by peripheral/pac. The reason your rear speakers don't work is probably because the original owner realized they are close to worthless.
m_0g
Jun 3, 2021 10:05 AM
Sailors350Z
Sep 25, 2015 08:21 AM
dmcgibbo
Nov 30, 2002 10:11 AM
troy_voorhees
Nov 17, 2002 06:37 AM
