Can somone who knows about AMPS and SUBS help me
Old Jun 28, 2011 | 01:56 PM
dalinkwent6's Avatar
dalinkwent6
Default Can somone who knows about AMPS and SUBS help me
I have a pair of MTX 10" thunder 4500 Subs (225 rms) and found a cheap amp Xplode XM-4060GTX 4/3 channel 600w. Would this set up work? any problems i would encounter? what does the 4/3 channel mean anyway?
Old Jun 28, 2011 | 02:12 PM
Ak48z's Avatar
Ak48z
You need to find another amp, the 4/3 means you can run 4 channels or you can run two channels and a subwoofer channel (3rd channel). Either way that amp doesn't put out enough power for your woofers.. and it pretty low on quality.
Look for an amp that does ~ 500 @ 2ohm... mono output subwoofer amp.
Good place to find a cheap amp is caraudio.com classifieds.
Old Jun 28, 2011 | 03:28 PM
dalinkwent6
how about this amp? MTX AUDIO JH202 JACK HAMMER 400W SUBWOOFER CAR 2CH AMP
Old Jun 28, 2011 | 03:56 PM
Ak48z's Avatar
Ak48z
Negatory... look for 250 RMS x 2 @ 2 ohm.... or 500 RMS x 1 @ 2ohm.... Either will work.... make sure you look for RMS watts and not " max " .
Old Jun 28, 2011 | 04:23 PM
dalinkwent6
hmm, do you mind throwin me specific amps that you would recommend for this pair? ill probably buy what you recommend cuz i know nothing. And something fairly cheap and not too expensive
Old Jun 28, 2011 | 04:33 PM
Ak48z's Avatar
Ak48z
Something like this... http://www.caraudio.com/forums/ampli...-p400-2-a.html
really your best bet is to sign up over at caraudio.com and place a wanted add for a 500rms @ 2 ohm amp.... you will get all kinds of offers good and bad... expensive and cheap...
Old Jun 29, 2011 | 03:32 AM
350zspl's Avatar
350zspl
it will move those subs , not to their max though, svc or dvc ?, i imagine svc 4 ohm , but look and see ?
Old Jun 29, 2011 | 03:39 AM
RENFRO's Avatar
RENFRO
How about don't buy cheap crap. By going cheap, more than likely you're not going to actually get the power that's advertised anyway.
Old Jun 29, 2011 | 06:32 AM
350zspl's Avatar
350zspl
those subs mtx 4500 are kinda let me say economy subs anyways
if you have them already throw them in with the sony amp
down the road when you get funds swap subs and or amp and or both
m_0g
Jun 3, 2021 10:05 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
Shane86
Sep 17, 2015 05:33 PM
