finding constant/switch power in doors
Old Aug 26, 2011 | 08:14 PM
bbs350z's Avatar
bbs350z
Default finding constant/switch power in doors
hey all, wiring up my wideband in my doors vent, looking for a constant or switched power to get this thing working. anybody have a clue what wire this is? cant find anytihng in the pdf file for the door area
Old Aug 27, 2011 | 10:20 AM
gvulakh's Avatar
gvulakh
Not sure if it's possible to pick up constant/switched power source from the doors.
I guess you're trying to avoid running wires into your door to power up the wideband? There might not be another way.
Old Aug 27, 2011 | 04:14 PM
hellogoodbye's Avatar
hellogoodbye
You could tap the red speaker wire I assume? Voltage will depend on watts going to it I believe.
Old Aug 28, 2011 | 08:58 AM
bbs350z's Avatar
bbs350z
yea im gonna give that a shot, worse case scenario ill pull more wires through where the factory wires go through
Old Sep 5, 2011 | 04:54 AM
KPierson_'s Avatar
KPierson_
There should be a constant power wire going in to the door for the windows. There should also be a RAP wire going in to the doors for the windows. My suggestion would be to drive a relay off of the RAP wire and run the constant power through the NO contacts of the relay to give you a high current RAP signal in the door.
However, it would probably be easier to just pull a true ignition source in to the door when you pull the wire for the wideband. You have to be careful with widebands, powering them with the car not running can damage them.
Old Sep 8, 2011 | 06:12 AM
Mike1082's Avatar
Mike1082
Please do not do this...
OP, your best bet is going to be running your own wires. If you know what you are doing with a digital multi-meter, you can check the door wiring for constant and switched 12v, but I would not recommend it.
Old Sep 8, 2011 | 01:34 PM
zakmartin's Avatar
zakmartin
The best solution is to tap directly into the fuse panel to the constant 12V source with something like a Bussmann mini add-a-fuse (click to link) If you need to run it off a constant power source, you'll have to remove your fuse puller to make room for it (there's only one constant 12V and that's to the stereo and it runs at 10 amps). If you want a switched 12V source, tap into the power side mirror fuse (I think that's 5 amps). The Add-a-Fuse takes up to a 10 amp fuse for the new accessory.
Just be sure to get the positive wire on the correct side (best to test with a multimeter). I know that on a 2008, red wire on the Add-a-Fuse should be facing UP if you're connecting to the constant 12V and should be facing down if you're connecting to the switched (mirror) fuse.
Since the fuse panel is so close to your vent, so you can just drill trough the molex connector next to the fuse box that runs to the door with a straight Dremel cutting bit, pass the wire through the rubber harness protector and up to the vent area. It should work like a charm and should only take a few minutes.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
