sound deadening question?
Old Dec 16, 2003 | 11:06 PM
ether's Avatar
ether
Default sound deadening question?
haven't decide yet what type of audio upgrade to do, but wanted at the same time to reduce the amount of road noise
I'm considering 2 options
#1 using sound deadening materials in the doors and covering the trunk area.
#2 using sound deadening materials for the doors, the trunk area and inside of where the stock sub and glove box are
wondering if anybody could comment on the reduction of road noise with either option
thanks
Old Dec 17, 2003 | 04:20 AM
ezee's Avatar
ezee
I did #2, it took alot of work but the results are fantastic, much quieter interior and a much more enjoyable ride. Stereo sounds much better, too.
Old Dec 17, 2003 | 05:07 AM
FLY BY Z's Avatar
FLY BY Z
I just did the floor and sides of the hatch and the strut tower bar in the rear and it made a world of difference. The Bose sounds even better now! Could use a sub, but hey, thats another story. Also, when you take apart the inside of the hatch you will see your air vents that let out air and equalize it. They have two little flaps on each one. I set them up to stay halfway open at all times. I could hear them flapping and it drove me nuts. It's really quiet back there now. It even eliminated buzzing of the plastic parts due to the aftermarket exhaust.
Old Dec 17, 2003 | 01:42 PM
MrGraphics's Avatar
MrGraphics
I went to a roofing supply house and picked up some dynamat-clone stuff (rubber base with aluminum top. Peal and stick.) I did the doors, the hatch (didn't remove the panels, just all the bare metal I could find under the spare) and the sub area. The audio quality definitely improved. Base is tighter. But I still get a lot of road noise on highway cement (asphalt is ok).
Anything else I could do to really quiet the car down?
Old Dec 17, 2003 | 02:45 PM
Hencho's Avatar
Hencho
dynamat - clone stuff called ice-shield ?
If im thinking of the right stuff, did you notice a smell to it, sorta chemical like ? I plan on using that instead of dynamat, as its much cheaper and looks dont matter behind panels.
Old Dec 17, 2003 | 03:15 PM
Jeff F's Avatar
Jeff F
FYI. The stuff with the alu layer is not nearly as good at dampening. The real power of dynamat and similar materials comes from the fact that it is "loaded" vinyl. For the material to be effective it actually has a oily base to it. This loading really helps. For this reason a small piece of dynamat placed at the center of a door panel could be far more effective than a large sheet of the wrong product. There are a number of materials made for commercial use with this property, but the minimum quantities are far to large for consumer purchase (expect for dynamat). It is widely used in industrial applications and things as varied as locomotive cabs etc.
Old Dec 17, 2003 | 04:46 PM
MrGraphics's Avatar
MrGraphics
The stuff I bought did not have a brand name attached. The roofing supply store was for contractors, thus the product came in bulk. But it is rubberized asphalt, and asphalt is derived from oil - so I would think the properties would be similar.
I thought the way that Dynamat works is by making the panel thicker and heavier, which then makes it resonate at a lower frequency. That gives it sound Deadening properties, but not sound Insulating properties (I believe there is a difference).
Old Dec 18, 2003 | 04:30 AM
ezee's Avatar
ezee
I also applied several coats of liquid FatMat as an undercoating to all 4 wheelwells before doing the interior. It was very effective at reducing road noise, and it quiets those pebbles that get kicked up by the tires.
You can find liquied FatMat at www.fatmat.com, it's $60 a gallon, goes on like thick paint, and dries to a flat black. A very good mod if you want to reduce road noise.
Old Dec 18, 2003 | 04:51 AM
ether's Avatar
ether
thanks for all the tips.. i'll cross check them with what the audio installer reccomends
Old Jul 5, 2004 | 07:07 PM
roydiculous's Avatar
roydiculous
ezee - did you just use 1 gallon for all 4 wheelwells? Any pics?
Old Jul 6, 2004 | 12:32 AM
stu46's Avatar
stu46
I used VB3 from Cascade Audion Engineering. Works great.
http://www.cascadeaudio.com/prod/vb3.html
Old Jul 6, 2004 | 06:21 AM
ezee's Avatar
ezee
Sorry, no pics. One gallon was enough to apply 2 thick coats to the outsides of all 4 wheelwells and the inside of the doors. Then I applied 2 more gallons around the hatch area, mostly above the muffler, the strut brace, and the insides of the wheelwells.
The interior is very quiet now, very little road noise and the stereo sounds much better. Also, the price on liquid FatMat has been reduced to $50/gallon.
Some tips if you're thinking of using the liquid: it doesn't stick to smooth painted surfaces too well. It sticks to the painted metal of the interior much better if you prep the surface by roughing it up a bit with steel wool or sandpaper. Once the first coat has dried then you can layer it on just like thick paint, just let each coat dry overnight before applying the next coat.
I also used masking tape to cover the exposed nuts and bolts, then I removed the tape after the final coat. When applying to the outsides of the wheelwells I covered the brakes rotors with newspaper to protect against drips. While it's wet the liquid cleans up easily with water, but I didn't reuse the brushes, I used a new 3" brush for each coat at the cost of $3-$4 each.
Old Jul 6, 2004 | 10:00 AM
silverstoneTT's Avatar
silverstoneTT
ezee- did you paint the liquid fatmat over the existing areas in the wheel well that seem to have some sound deadening material?
Old Jul 6, 2004 | 12:29 PM
silverstoneTT
fLYBYZ--or anyone for that matter--
"They have two little flaps on each one. I set them up to stay halfway open at all times. I could hear them flapping and it drove me nuts. "
Does anyone have pics or direct me to where this is and how I can get to it?
Old Jul 6, 2004 | 01:19 PM
ezee's Avatar
ezee
Yes, I left all the original stuff in place and painted right over it.
Old Jul 6, 2004 | 01:20 PM
silverstoneTT
But did you paint on any other areas or just over the area that already had stuff?
Old Jul 6, 2004 | 01:42 PM
ezee's Avatar
ezee
I applied the FatMat EVERYWHERE behind the seats, including the wheelwells, strut brace, glovebox and subwoofer areas (I can no longer hear the fuel shoshing around), everywhere except the ceiling because there is no noise coming from above, only from below.
Everything behind the seats has been coated. When I had the trim out I also replaced all the speakers and installed a BaseLink, which by the way sounds great. I figure 3 gallons of FatMat added about 20-25 pounds to the car's weight, but the ride is so much quieter it was well worth the effort and expense.
lapham3
Oct 7, 2022 03:15 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
Alexreyes
Sep 30, 2015 11:30 PM
samansharif
Sep 25, 2015 12:31 PM
