Car Audio Help(Amp)
Old Nov 15, 2011 | 03:36 PM
carlili4190's Avatar
carlili4190
Default Car Audio Help(Amp)
So my amp died on me the other day. I went out and purchased an Alpine MRP500. I went to install it(should be plug and play) and got everything put in. However the remote wire won't turn on the amp for longer then 5 seconds. If I hold the wire/screw in the wire to the amp it will turn on and then it will turn off. I know power is getting to the amp because it will turn on but it won't stay on. I checked all the connections and they all seem fine... Any idea why this is going on?
Here is a video that kind of explains what I am trying to say....
[flash=http://www.flickr.com/apps/video/stewart.swf?v=109786]width="" height="" flashvars="intl_lang=en-us&photo_secret=&photo_id=6348413757" bgcolor="#000000" allowFullScreen="true"[/flash]
Heres a link incase it doesnt imbed
http://www.flickr.com/photos/27906623@N07/6348413757/
Old Nov 15, 2011 | 03:40 PM
THEDUKE's Avatar
THEDUKE
Try unplugging the speaker outputs and then give it a try. If it stays on, then you also have a problem with your speakers.
Old Nov 15, 2011 | 04:28 PM
carlili4190
Tried that already. Amp still goes off after about 5 seconds.
Old Nov 15, 2011 | 04:43 PM
saywat?'s Avatar
saywat?
try test with a new fuse block (the one running your pwr wires from the battery to the amp. i had a faulty one and it was doing something similar to urs.
Old Nov 17, 2011 | 12:29 PM
KPierson_'s Avatar
KPierson_
Whats the voltage from the amps ground terminal to the amps power terminal? What is the voltage from the amps ground terminal to the amps remote terminal?
Old Nov 17, 2011 | 12:50 PM
ccswift's Avatar
ccswift
The M500 has a switch for the power-on type. Check this. Mine had the same thing from when I bought it.
m_0g
Jun 3, 2021 10:05 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
