15" slot port box in my Z
Old Dec 8, 2011 | 04:20 PM
johns350z's Avatar
johns350z
Default 15" slot port box in my Z
Im thinking of upgrading my 2 - 10" FI Q's to 1 - 15" FI SP4. I am designing my box and wanted to put it out there and get some feed back from people more experienced with ported boxes than I am. I am extremely happy with the outcome of my 10's but of course there is always room for more. Oh btw I am pushing them with 2 Crescendo BC 2000 at 1 ohm, nominal 4,700 watts.
The box I am thinking of will be 31" W x 15" H x 19 " L. I was told by FI to make my port width no smaller than 4 inches but that is practically impossible with this application. I want port up, sub up. So I was thinking of 2.75" port width, total port length 36". This gives me a net box of 3 cuft without speaker displacement and tuning of 32htz.
Feel free to add comments If you have experience that you dont mind sharing.
Old Dec 8, 2011 | 04:55 PM
dkmesa350z's Avatar
dkmesa350z
In for updates.
If your FI Qs are D4, I will take one off your hands
I've considered putting a slotport 12" enclosure back there...but the 10 works just fine for me these days.
Old Dec 8, 2011 | 05:18 PM
johns350z's Avatar
johns350z
D4? Are you refering to the ohms? FI doesnt make a dual 4, only dual 1 (.7) or 2 (1.4). Mine are dual 1 (.7) ohms.
Old Dec 8, 2011 | 06:36 PM
dkmesa350z's Avatar
dkmesa350z
hmm forgot about that. Can a single D1 be wired to 2 ohms total resistance? If so, I'd still be interested if you sell them.
Old Dec 8, 2011 | 06:59 PM
johns350z's Avatar
johns350z
Yes you can connect the sub in series, + of coil 1 to the - coil 2. Then you hook up the speaker wire from the amp to the - of 1 and + of 2. This gives you a 2 ohm load. Yes I do want to sell them, I want 500 shipped for both. They are fully upgraded with options. What amp are you planning to run these with? You can hook these at 1 ohm mono or 4 ohm mono together.
Old Dec 8, 2011 | 07:03 PM
johns350z's Avatar
johns350z
Default Here they are
http://www.caraudioclassifieds.org/f...ly-loaded.html
Old Dec 8, 2011 | 08:24 PM
johns350z's Avatar
johns350z
How about an aero port? Rick at FI told me to use 1 - 6" aero port if i was having problems getting down to 32-35 htz. Can someone please explain to me what length I should use, where I can buy aero port cheap and do I need to use an elbow?
Thanks,
John
Old Dec 18, 2011 | 04:39 PM
jbrueshaber's Avatar
jbrueshaber
Thanks,
John
Man, you can purchase aero ports at www.parts-express.com. The longer and/or wider the port the lower your box will be tuned. However, watch out overdriving/clipping those Q's. They have crazy, good X-max for 10's, but overtime the lower tones will shorten the life of the subs. I had two Fi Q 10's previously, and I blew them both. My box was tuned around 30 hz, and I playing nothing but chopped and screwed music. LOL! Hope this helps.
Old Dec 19, 2011 | 05:18 AM
johns350z's Avatar
johns350z
Thanks for the reply. I actually have a good understanding of how slot and aero ports work now. I did some research and learned how to achieve my required port area and desired box tuning frequency. Your comment of "The longer and/or wider the port the lower your box will be tuned" is a little off. The longer you make your port the lower the tuning but the wider you make it the higher the tuning will be. If you use a 6" port vs a 4" port your lengths with a 6" has to be substantially longer to achieve the same frequency.
Ive had my Qs for about 3 months now and Ive put them in three different boxes and the box they are in now is by far the best. I had to reinforce the slot port and double the baffle. I am pushing them pretty hard and they are taking it like champs. I clamped it a while back before i raised the gain up again and I got 3,800 watts going to them. So they are powerful little suckers. I am getting a good amount of flex in my car I just wanted to upgrade because I felt if I got more cone area I would have to push it less to get the same output.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
