Rear speakers dead - any advice?
Old Dec 20, 2011 | 08:55 AM
austinJim's Avatar
austinJim
Default Rear speakers dead - any advice?
Hi all,
I have a 2004 350z coupe with the base (non-Bose) audio system, no nav. I've replaced the factory head with an aftermarket. It's been working fine for years but now the rear speakers have stopped working. I pulled the head and it's producing a signal to the rear speakers so it's not the head.
I've checked the wiring diagrams but I can't figure out if this system has a rear speaker amp even thought it's not a bose system. Can anyone suggest what I should do next? Where is the rear amp, if any?
Thanks!
Jim
Old Dec 20, 2011 | 09:32 AM
Factory service manuals are available on the internets. Very helpful. Get yours free.
Old Dec 20, 2011 | 09:39 AM
austinJim's Avatar
austinJim
I do have the manual and it seems to say that the non-Bose system still has a rear speaker amp. I'm hoping someone can verify that for me in case I'm misreading the manual, and can tell me where it is in the car.
Thanks
Jim
Old Dec 20, 2011 | 09:52 AM
VO...'s Avatar
VO...
Administrator
Moved
The amp is located on the driver's side where the spare tire well is. It's under the black styrofoam when you lift the false floor...
Old Dec 20, 2011 | 11:56 AM
austinJim's Avatar
austinJim
Thanks!
Old Dec 20, 2011 | 01:03 PM
bmccann101's Avatar
bmccann101
the speakers are total crap, theres no amp, and they should simply be replaced.. i do not doubt that your wiring is 100% fine and its the speakers.
all of them should actually be replaced.. they are literaly the worst speakers ever put into a car.
Old Dec 20, 2011 | 02:04 PM
tquill's Avatar
tquill
Aren't the rear speakers worthless anyway? I had always thought they might as well be disconnected... and the door speakers carry 100% of the sound.
I'm no audio expert though.
Old Dec 20, 2011 | 02:32 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
The stock rear speakers provide fill, which is what rear speakers are supposed to do. They're pretty weak, but they do provide some sound.
Old Dec 20, 2011 | 03:06 PM
Rocknthehawk's Avatar
Rocknthehawk
exactly! It gets tiring reading posts saying the rears are useless and don't bother with them. They're not in the greatest location, but they do have a purpose.
Old Dec 20, 2011 | 04:25 PM
Spike100's Avatar
Spike100
This is a useless posting. Please refrain from posting useless information which unfortunately you frequently do. People who do not visit the sight regularly may be confused by your messages.
--Spike
Old Dec 20, 2011 | 07:52 PM
When you find the amplifier for the rear speakers, please post photos. Much appreciated.
Old Dec 21, 2011 | 07:26 AM
VO...'s Avatar
VO...
Administrator
^^ I figured the amp for for the Bose sub that went behind the driver's seat, but I figured I'd tell him where it was at anyway...
Old Dec 22, 2011 | 06:02 AM
austinJim's Avatar
austinJim
The rear speakers were both dead. I guess I drove them a little too hard! They are really, really cheap speakers. I did remove and replace them with a pair of Kicker DS65. They were less thank $70 at Frys. Probably the best $70 I ever spent on the car! I used the following post as guidance. It has plenty of pics on disassembly:
http://www.350zmotoring.com/forums/a...u-tell-me.html
I read somewhere that some speakers are not flush enough to use the factory grills. I didn't want to get into modifying the plastic pieces so I made sure I got speakers that did not protrude too much. These speakers fit fine with no modifications to the plastic or to the metal (other than removing small metal tangs that may have been used to hold the original speakers in place before they were screwed in).
Thanks for the help!
Jim
Old Dec 22, 2011 | 06:24 AM
Jim
Glad that worked out for you. BTW did you find the amplifier for the rear speakers?
Old Dec 22, 2011 | 06:35 AM
austinJim's Avatar
austinJim
There's no amp for rear speakers in the base system. I was misreading the manual.
Jim
Old Dec 22, 2011 | 07:12 AM
tquill's Avatar
tquill
Have you replaced the door speakers as well?
Old Dec 22, 2011 | 07:15 AM
Vivid Racing
Vivid Racing
Wow, you actually came back and updated your thread... Nobody ever does that! Thanks for the update.
Old Dec 22, 2011 | 12:57 PM
austinJim's Avatar
austinJim
Ha! In addition to my Z, I have 2 old British sports cars (1976 Triumph TR6 and 1978 Spitfire). I depend on lots of advice from folks on the net and I know how frustrating it is to find a thread that talks about a problem without giving a complete solution. So, I do what I can!
Old Dec 22, 2011 | 12:58 PM
austinJim's Avatar
austinJim
No, I just replaced the rears since they were out. But, the sound is a lot better so I'm now considering replacing the fronts as well.
3vilbunny
Jul 18, 2017 05:10 PM
