pioneer double din install
Old Mar 2, 2012 | 11:57 AM
jmy24's Avatar
jmy24
Default pioneer double din install
so i've been trying to install a double din and followed the instructions here: http://web.me.com/orbitalpunk/orbitalpunk/Avicd3.html
my harness looks exactly like the one that he has in the second picture of that guide.
I've been using a single din with aftermarket speakers + sub + amp. It worked perfectly. No issues.
I disconnected the single din and tried installing the new head unit with the new harness as well. The problem is I can't seem to get the head unit turned on. My amp isn't turning on either.
I can't figure out what I'm doing wrong. I grounded the wires like I was supposed to from the guide.
Can you guys help me figure out what I may be missing? or what I may need to take a look at?
Old Mar 2, 2012 | 12:22 PM
AznSky's Avatar
AznSky
Make sure your ground has a good connection to bare metal. That's really all I can think of besides checking your power cord is plugged in lol
Cuz I would think it should turn on regardless if there's power and ground.
Old Mar 2, 2012 | 12:25 PM
jmy24's Avatar
jmy24
Hm. wouldn't the ground that I've been using be fine for the new install?
Old Mar 2, 2012 | 03:22 PM
BipJip's Avatar
BipJip
all aftermarket radios only need a few connections. yellow = 12v+ batt, red = 12v+ switched (key on), color pair = speakers, and black = 12v- ground. as long as all fuses are good the head unit should turn on. with an added am youl have to hook up RCA's and the blue wire to amp turm on. if it dont turn on check all your connections they should be soldered and shrink tubed, please dont just electrical tape your wires!
Old Mar 2, 2012 | 03:58 PM
TURBOROADSTER's Avatar
TURBOROADSTER
Make sure antenna is plugged in .
Old Mar 2, 2012 | 04:06 PM
sdZ33's Avatar
sdZ33
Make sure the fuses aren't blown first.. Then make sure that the black wire coming from the actual stereo is grounded to the cars metal and not the harness of the car... You can ground it using one of the stock screw locations...
Old Mar 3, 2012 | 03:34 AM
Duro's Avatar
Duro
Make sure you don't hot swap your rcas you will blow the Pico fuse.
Old Mar 3, 2012 | 07:12 AM
jmy24's Avatar
jmy24
thanks guys for yalls suggestions! i got it working now. it seems like i didn't ground it right the first time. but it's all good now!
EnjukuRacing
Sep 30, 2015 06:55 AM
