OEM Navi not turning on......
Old Mar 8, 2012 | 04:28 PM
TwoFastFurYa's Avatar
TwoFastFurYa
Default OEM Navi not turning on......
So I turn on my car and thr Navi door slides up, but the screen doesnt turn on. Ok, so I turn off the car, turn it back on and the same thing. Navi door slides up, and screen doesnt come on at all, so the door slides back down bc the screen wasnt on. But, sometimes when I turn on the car the screen works just fine. Whats causing this to happen? Meaning, whats causing the screen not to come on at times, then work at times?
Old Mar 8, 2012 | 05:16 PM
kevincat's Avatar
kevincat
try to go to settings and make sure that navigation isnt turn off. sometime if the screen turn black, you could turn it on by pressing settings
Old Mar 8, 2012 | 06:43 PM
TwoFastFurYa
Its not turned off hence why it comes on sometimes and sometimes not
Old Mar 12, 2012 | 09:21 PM
TwoFastFurYa
Now its not coming on at all.....I will upload a video showing whats doing for you guys.
Old Mar 12, 2012 | 09:47 PM
TwoFastFurYa
http://m.youtube.com/watch?v=RAwuJ-shRIU
Old Mar 12, 2012 | 11:35 PM
kevincat's Avatar
kevincat
looks like the cover is not going up all the way to trigger the navi on. i remember this happening to me right before my navi cover motor dying on me.
Old Mar 13, 2012 | 07:16 PM
TwoFastFurYa
Ok, so everytime I start the car I wait for the cover to open and give it a slight nudge before it stops at the stop.....and VOILA!! Comes on now! Only when I nudge it before its all the way open. Is there a fix to this?
Old Mar 14, 2012 | 02:36 PM
kevincat's Avatar
kevincat
yeah take the console out and unplug the ribbon to the motor door. make sure the navi door is open all the way before removing the ribbon. hope this helps
Old Mar 14, 2012 | 05:19 PM
Spike100's Avatar
Spike100
No one can give you a definitive answer that solves your problem because the fault is based in a mechanical failure. You already determined the “fix,” but it’s not pretty or convenient. Your problem and its repair/solution is why Nissan eliminated the retracting door on the upper/forward cubby in favor of an open design.
For your problem, I would disassemble the center console and all its components, and then put it all back after carefully checking every switch and connection. If that fails, it’s time to begin researching aftermarket solutions.
--Spike
Justin100
Nov 25, 2021 06:26 AM
350z82
Oct 1, 2015 06:25 PM
