Car Computer Audio Question
Old Jan 15, 2004 | 05:11 PM
DMD's Avatar
DMD
Default Car Computer Audio Question
I finally got my car computer in my car but have a question about the quality. I used to have an Eclipse HeadUnit and had a LOUD option which increased the bass by quite a bit w/o distortion. How do I achieve this effect on the computer? I am using a Mini-itx with a mini-jack to RCA cable that plugs into the amp which feeds my front component speakers and my 10" Sub.
I try media player and used the WOW SRS affects and that helps but is not the same, and if I use the equalizer the front speakers begin to distort.....Any ideas?
Old Jan 15, 2004 | 11:26 PM
the O.Z.'s Avatar
the O.Z.
Default Re: Car Computer Audio Question
I would suggest turning the computer volume to about 70%. Maybe even as low as 50%. This will keep the speakers from distorting.
Old Jan 17, 2004 | 12:15 PM
funkdamonkman's Avatar
funkdamonkman
NO, I would have the computer sound at 100%
If you have an amplifier trying to amplify a weaker signal, you will get more "noise".
Try using winamp .. www.winamp.com
It has equalizer presets, and you might be able to find a skin that will make it easy to use on the car pc screen.
Old Jan 17, 2004 | 04:23 PM
the O.Z.'s Avatar
the O.Z.
If this was a "line out" from the computer I would agree with you. but... it is most likely the typical headphone/speaker jack. It has a little bit of wattage behind it. I have found that if you turn your computer volume down a little bit when connecting to external amplifiers, you get a cleaner sound.
I suppose I could be wrong though
Old Jan 17, 2004 | 05:48 PM
DMD's Avatar
DMD
Not sure how to fix this but I think I have a solution! I am getting a Nakamichi CD 400 HeadUnit which has a AUX in, so if I feed my computer line out into the headunit I should be able to use the LOUD function on the HU and the sound should sound perfect again....I hope! I have been looking to replace the eclipse HU anyway.
Old Jan 17, 2004 | 06:07 PM
hybridart's Avatar
hybridart
the mini jack to rca always creates unwanted noise. i had this problem when hooking my computer to my surround sound in my living room...the best way i resolved that was to use a thicker monster cable. i'd also say try the above suggestions as well.
Old Jan 17, 2004 | 10:07 PM
alphared's Avatar
alphared
You should look at getting an another sound card. the onboard ones are crap. I had similar problem with the onboard (that and static) ended up getting an usb sound card and works great (has treble and bass setting, unlike the onboard) Also, if you're splitting your connection to the amp (seems like it from your post) your HU gonna overpower the PC output. if your HU has gain adjustment, tune it down and raise the gain on the amp so that the HU and PC are same volume.
But, since you're getting a HU with AUX in, that should solve your problems.
Old Jan 18, 2004 | 07:35 AM
funkdamonkman
ok, that makes sense.
In that respect, can you plug a computer into a amp that takes line level imputs?
Old Jan 18, 2004 | 08:46 AM
the O.Z.'s Avatar
the O.Z.
You could do it... but I dont think you would be happy with the sound. You would have to turn the gain on the amps WAY up and this might amplify all of the noise as well. The output jack from a computer has a very small amount of wattage... nothing like a headunit puts out. I agree with one of the previous posts... then best solution is to buy a nice sound card that has RCA outs.
Old Jan 18, 2004 | 09:25 AM
DMD's Avatar
DMD
Which soundcards have RCA outs?
Old Jan 18, 2004 | 11:56 AM
bastard's Avatar
bastard
I know the Creative Sound Blaster AWE64 did have RCA outs. Not sure what new ones do.
Old Jan 20, 2004 | 07:35 PM
GSRto350Z's Avatar
GSRto350Z
Radio Shack will have a 3.5mm to RCA converter jacks.
Old Jan 20, 2004 | 07:56 PM
alphared's Avatar
alphared
Are we going back in loops now?
jlb
Oct 15, 2017 05:10 AM
SonnyWu
Nov 24, 2015 08:19 PM
Vigman
Nov 17, 2015 04:34 AM
SanmarinoZ
Oct 21, 2015 10:04 AM
Ace2347
Sep 22, 2015 03:12 AM
