Issues =/
Old Mar 25, 2013 | 09:55 AM
aleda21's Avatar
aleda21
Default Issues =/
Hey guys installed my 4 new speakers dxi 6500 with the jbl gto5ez amp this weekend everything went decently smooth (thanks to the door wiring post) buttt my amp takes about 30-45seconds to actually kick in and some times randomly shuts off also high pitch whine in the speakers but thats probably just needing better/ another ground any suggestions?
Old Mar 25, 2013 | 10:09 AM
ProChargedZR's Avatar
ProChargedZR
According to Crutchfield, the amp's class is AB/D. How hot is the amp getting when it turns off? Also have you verified that the remote on wire is firmly connected?
Old Mar 25, 2013 | 10:13 AM
aleda21's Avatar
aleda21
not very hot and yeah remote wire is very secure also i have to turn the volume to almost max to get it to initially kick in
Old Mar 26, 2013 | 06:38 AM
DemandedAce's Avatar
DemandedAce
A bad ground can cause all of these issues, I would first find an unpainted bolt to the frame and move the ground there and see if the issue is still around. If the issue is still there try a little experiment in jumping the remote on wire, just disconnect your remote wire from the H/U and drop a tiny wire between the +12V and Remote terminals and see if it immediately starts up.
Old Mar 26, 2013 | 05:58 PM
Collin Lacy's Avatar
Collin Lacy
+1 bad ground.
Old Mar 27, 2013 | 06:14 AM
aleda21's Avatar
aleda21
any good places to suggest to move the ground to?
Old Mar 27, 2013 | 06:24 AM
K51's Avatar
K51
Look for a bolt or screw in the chassis/body where the bare threads of the bolt are in contact with bare metal on the chassis. If needed, you can scrape/sand away some of the paint around the female threads of the bolt hole so the ground wire makes good contact with the chassis. Use a ring terminal crimped onto your ground wire, rather than just jamming the bare wire under the bolt head.
Old Mar 27, 2013 | 10:49 AM
aleda21's Avatar
aleda21
yeah what i have now a bolt behind the plastics with a pre-made ground 4ga wire think i might move it today
Old Apr 3, 2013 | 09:33 AM
DemandedAce
Did it turn out to be the ground after all?
Old Apr 9, 2013 | 08:22 PM
aleda21's Avatar
aleda21
Nope still randomly cuts out could be 10 seconds after start up could be 30 minutes its like the remote wire isnt giving a signal just the RCA cables and it gets confused i did change the ground and it def helped with the whining sound
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
