Focal speakers
Old Apr 24, 2013 | 03:56 PM
Ryan_zgk's Avatar
Ryan_zgk
Default Focal speakers
Hi all guys,
I am thinking about upgrading the speaker system on my 08 350z. I really like Focal brand so I want to ask you guy that what models of Focal is good? I need 2 speakers and 2 tweeters on doors, 2 speakers behind the seats, and an amplifier, and I only can spend around $1000 ).
Thanks all
Old Apr 24, 2013 | 04:23 PM
Spike100's Avatar
Spike100
I mounted the Focal 165 V Slim (depth from wall: 56mm (2.2")) in the stock door position. The sound is absolutely great. I’m uncertain which comparable Focal model is available now; Focals are great sounding speakers.
Because your budget is tight, you might consider replacing only the front door components, and disconnecting the cheap OEM rear speakers.
Of course you will want an external amp to drive high quality speakers (as the Focals). You don’t need to spend a lot on the amps
--Spike
Old Apr 24, 2013 | 05:09 PM
Ryan_zgk's Avatar
Ryan_zgk
Thanks Spike. Do you think I need to replace all speakers' wires?
Old Apr 24, 2013 | 05:37 PM
07maximan's Avatar
07maximan
I have the PS165's. They sound great but some times the tweeter gets a little harsh. If I was going to buy Focals again I would buy some of the higher end ones.
Old Apr 24, 2013 | 09:39 PM
Collin Lacy's Avatar
Collin Lacy
If you want crazy good sound and can move away from focals,
Get these: http://store.12velectronics.com/imag...l-speaker-set/
Put them in these: http://wickedcas.com/product.php?pro...&cat=27&page=1
Powered by something like this: http://www.sonicelectronix.com/item_...PAD2000.2.html
And throw away your rear speakers like Spike said.
Edit: you don't HAVE to run new speaker wire. When I first did my speakers I ran new wires up to the doors, but spliced the old ones so I didn't have to run them through the molex. Made it much easier and never had a problem with a 120watt RMS (per side) amp. If you have the patience its a much better idea to run new wires all the way though.
Old Apr 25, 2013 | 03:14 PM
Spike100's Avatar
Spike100
As Collin Lacy states, you don’t need to run new wiring. I left the factory wiring in place and get excellent sound from the Focals. --Spike
Old Apr 25, 2013 | 06:18 PM
Spike100's Avatar
Spike100
Just curious… Where did you mount your Focal tweeters?
--Spike
Old Apr 25, 2013 | 06:24 PM
07maximan's Avatar
07maximan
--Spike
On the windshield pillars.
Old Apr 26, 2013 | 06:14 AM
Nuked's Avatar
Nuked
I have the Focal 165A3 set in my 03. Been very happy with them.
Old Sep 6, 2013 | 06:06 AM
Cujo159's Avatar
Cujo159
I had focals in my first Z but as of yet don't have a system in my Nismo... and it's killing me lol. THe Focals were awesome but expensive. Collin Lacy, with those door pods, do you have issure with leg room clearance and getting in and out of the car?
Old Sep 6, 2013 | 02:05 PM
RedlineRedZ33's Avatar
RedlineRedZ33
I have the PS165's, and while I'm completely satisfied with them, I would HIGHLY recommend getting either door pods or kick pods. I'm getting ready to buy a pair of door pods for mine because there is no way to get rid of the rattles in the door without them, and it ruins the sound quality of the speaker immensely.
Old Sep 12, 2013 | 07:59 AM
Nazar's Avatar
Nazar
Focal is a great line...
If you could check out the HERTZ AUDIO LINE..
I can run you a package deal with our door pods and a pair of components.
I will guarantee you the sound.
Old Sep 13, 2013 | 03:30 PM
harmysZ's Avatar
harmysZ
i have door pods and the K2 seris sound amazing only the tweeter can get a little loud but I also dotn reccomend the rear speakers I spent 450 on second set of focals biggest waste of money all you need is oen set in front.
Old Sep 13, 2013 | 04:23 PM
Cujo159's Avatar
Cujo159
How's leg clearance with the door pods. Also how much were the K2's?
Old Sep 14, 2013 | 06:23 AM
harmysZ's Avatar
harmysZ
i bought my K2 few years ago and have shitty canadian prices lol... the pods leg clearance is good no complaints on teh Wicked CAS oens at all .
Old Sep 16, 2013 | 07:33 PM
Spike100's Avatar
Spike100
Yes... Your door pods provide a significant improvement in the sound.
Old Sep 17, 2013 | 03:57 AM
beezee's Avatar
beezee
door pods are great. Kick panels are even better. As far as leg room, you just need time
to get used to it. There will be times when you would kick them. Main problem i had with door pods was passengers. They are more likely to bump them. A little screem and warning helps
Old Sep 17, 2013 | 05:05 AM
Cujo159's Avatar
Cujo159
Could you expand upon how the kick panels are better? Have you had both? And could you provide a link to some examples? Thanks!
Old Sep 17, 2013 | 05:31 AM
Nazar's Avatar
Nazar
Best set up would be having Kick panels for 5.25" and tweeter and our door pods for mid-bass....
But I guarantee our door pods to make your speakers (any brand) sound twice as good with more mid-bass... Vs stock location.
Old Sep 17, 2013 | 01:23 PM
beezee's Avatar
beezee
I have have Infinitty kappa Perfect components in the front. i started out with the stock location with tweeters in the stock location as well.
They sounded better than my Bose. Then I followed the directions in threads by SimplicityInSounds (a member here too) and made pretty good door pods.
The difference was very very significant. ( Anyway my doors are very well sound deadened). I liked them but out of curiosity and also something to keep me busy, I made kick panels also by following every step as laid out by his other threads. Now I am done and they are not going anywhere. The difference between door pods and Kicks is not as big as the difference between Door pods and stock location. If done well (example from NAZAR) they will be very clode to Kicks but i must say kicks in my oppinion are better
I have the tweeters in the A-Pillar now. Let me add that NAZAR has proven quality pods. Actually I was going to buy from him but i found out my Infinnitys would not quite fit.
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
