Double Din that Looks stock
Old Nov 19, 2013 | 10:57 AM
cavallino33's Avatar
cavallino33
Default Double Din that Looks stock
Looking for a double din head unit that really looks like it could be stock down to the orange LCD. Doesn't need to be fancy just sound as good as stock with stock speakers but have an additional auxiliary input. Don't need satellite radio or cassette or even a cd player if I have aux input.
Old Nov 19, 2013 | 11:10 AM
07maximan's Avatar
07maximan
Pioneer AVH series. They have selectable button color as well. They have some inexpensive models as well.
Old Nov 19, 2013 | 11:11 AM
travlee's Avatar
travlee
Master
^ what he said, i have the avh-4300dvd (i think) and you can custom choose the color
Old Nov 19, 2013 | 12:23 PM
dcains's Avatar
dcains
I think pretty much all aftermarket double-DIN's allow for color choice on the illumination. Anything with a flat screen is going to look different from OEM, but some are more stealthy than others.
I've got an extra Kenwood DDX516 I just took out of my '08. If you've got an '06+ the wiring harness will plug right into your car's original wiring. You would need to buy the dash trim kit, though, which is ~$15. Shoot me a PM if you're interested, and I can send some pics. I've got the Kenwood iPhone/iPod cable, too.
Old Nov 19, 2013 | 03:55 PM
Spike100's Avatar
Spike100
As dcains states, double-din H/U’s from better manufacturers can match the Z’s color screen.
Nissan uses Clarion as an OEM provider. I have a Clarion H/U in my 350z, and the color match is exact. The color is “Warm Amber.” Go with a Clarion H/U if you demand an exact color match.
--Spike
Old Nov 19, 2013 | 09:23 PM
dcains's Avatar
dcains
Both the Kenwood's I've had (the aforementioned DDX516, and now the DDX470) can be adjusted to a near exact match, too. There are a bunch of preset colors, but then also manual/custom control of the individual RGB levels. I don't know if these pictures show it well enough, but first the DDX516 and then the DDX470 (you can even change the background image):
Old Nov 21, 2013 | 01:08 PM
DarkCreep's Avatar
DarkCreep
I have the DDX470 and I set it to match the interior. Its not a perfect match but its damn near close! I love how OE it looks.
Old Nov 21, 2013 | 01:32 PM
92K1500's Avatar
92K1500
Be careful what you pick though. If you have one with a motorized face the dash kit trim ring thing will not fit. You have to cut the top part out to clear it and it looks like poo....... I'll post some pics of mine tonight when I get home for you.
Old Nov 21, 2013 | 06:58 PM
92K1500's Avatar
92K1500
Sorry for the crappy quality.
I'd say the color of the buttons match fairly well on my Pioneer.
The flash makes my dash look horrible. It is starting to mess up around the fan speed **** pretty bad though.
There you can see I had to cut the top strip out to make enough room for the face to move.
Old Nov 22, 2013 | 03:42 PM
92K1500's Avatar
92K1500
Here is a better daylight picture.
Old Nov 22, 2013 | 05:43 PM
CptWiggles's Avatar
CptWiggles
I think you can find the stock unit on ebay or something that is modified to have an aux port in it. If you're looking for another solution though I would highly recommend the Pioneer Appradio. With a little bit of work you can fully integrate your smartphone with your system. It can give you the ability to display your smartphone on the unit and interact with the unit on it's large screen and have access to everything you normally would on your phone. I've completed my install which looks very much like the one below. It's almost like a carputer, but it's far more useful and flexible.
Old Nov 22, 2013 | 07:03 PM
92K1500's Avatar
92K1500
I have the appradio mode in my head, but I can't figure out how to get it to play music off the usb or SD while I'm using nav on my phone...
The only way I can get it to play music at the same time is to use pandora.
Old Nov 22, 2013 | 07:55 PM
CptWiggles's Avatar
CptWiggles
I rooted my Android phone and use ARliberator to see exactly what I see on my phone, if you have an iPhone I believe you have to jailbreak it and figure however that works out. But once you can do that, you can just load your music onto your phone and play it locally on there.
Old Nov 22, 2013 | 08:41 PM
secwind's Avatar
secwind
Here's what Pioneer AVH series look like.
Old Nov 22, 2013 | 08:43 PM
secwind's Avatar
secwind
iPhone equivalent of ARliberator is called AppRadioExtension.
Old Nov 23, 2013 | 07:36 AM
92K1500's Avatar
92K1500
I have that and it still wont do it...
And I don't have any music on my phone. I have a 16gb phone and about 100gb of music. It wont all fit. So if I want to listen to music on my phone I use webaccess to my HDD at home or I listen to Pandora.
Otherwise I use the SD card and a couple USB sticks in the car.
Old Nov 24, 2013 | 08:53 AM
secwind's Avatar
secwind
I don't have that problem with mine even with a locked iOS7.
There's a setting under system called "App Sound Mixing." You need to turn it on in order to get music playing in app mode.
Old Nov 24, 2013 | 08:56 AM
92K1500's Avatar
92K1500
Ohhhh. Gotcha. I'll try that.
EnjukuRacing
Sep 30, 2015 06:55 AM
