Lights Dimming
Old Feb 8, 2004 | 01:36 AM
Dre Dizzle's Avatar
Dre Dizzle
Question Lights Dimming
Hey y'all, I have a 10W7 with a 500/1 amp and just recently I've noticed that my lights dim when the beat hits. I have a 1 farad cap and changed the fuses. I have 8 gauge wiring with the amp, do I need to change them to a 4 gauge, or is the problem unrelated? Thanks in advance!
Old Feb 8, 2004 | 04:47 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I would definitely switch to 4 gauge for the amp and cap.
Old Feb 8, 2004 | 06:32 PM
macka's Avatar
macka
The problem is not your wire, I have 4 gauge from battery to amp; as well, I have a 1.5 farad cap. The problem is the alternator, not the install. Whatch your volt meter on the dash when the bass hits, if it drops, you need a new alternator. Also you might try using a yellow top battery. The Z has a good alternator, but it could be better, especially if you play music with a lot of low bass.
Old Feb 9, 2004 | 01:36 PM
dczoner's Avatar
dczoner
Man oh man, you guys would've died in a 300zx. At least the 350 has like a 120a Alternator, the best I could find on the 300 was the 85a 96 Twin Turbo Alt. . .
Old Feb 13, 2004 | 05:32 PM
hndumafia's Avatar
hndumafia
on a side note you should upgrade your wire to 4 ga. it is strongly recommended for the JL amps to use 4 ga.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
