Window Roll up with OEM remote
Old Jul 23, 2004 | 08:50 AM
  #241
myz8a4re's Avatar
myz8a4re
thats correct, one module=both windows roll up.......
-justin
Old Jul 27, 2004 | 12:52 PM
  #242
cyclopz's Avatar
cyclopz
I recieved both mod units yesterday and installed both today. No problems at all!! Both are working perfectly. For the TCS mod I picked a wire off the brake switch at the pedal for the 12v ignition wire, it only gets current with the ignition in the on position. Does anyone forsee a problem with using that wire? It was soo easy to tap into and right behind the TCS switch.
Thanks Kevin great mods and easy install
Old Jul 27, 2004 | 01:26 PM
  #243
KPierson's Avatar
KPierson
Glad you like them. I'll look into the brake wire, but it shouldn't be a problem. These modules draw such a small amount of current that as long as everything is working right you should be able to get power for them anywhere in the car, as long as its 12vdc.
Thanks,
Kevin Pierson
www.KPtechnologies.net
AIM: KPiersonTec
Old Jul 28, 2004 | 01:15 PM
  #244
ZRACING's Avatar
ZRACING
can u check ur PM
thanx
Old Aug 14, 2004 | 07:57 AM
  #245
sflg35's Avatar
sflg35
KP Technologies
bump
hows everyone doing? anyone still havin problems.
kevin should have somemore ready to go in a few weeks
Old Sep 15, 2004 | 06:37 PM
  #246
sal1's Avatar
sal1
Kevin, I have something weird or should I say unusual. I unlock the doors with my FOB and about 60 seconds later the doors lock automatically. What's happening? Sal
Old Sep 15, 2004 | 06:50 PM
  #247
DavesZ#3's Avatar
DavesZ#3
Mine does that and I don't have Kevin's unit. If you unlock the door but don't actually open it, they will relock themselves. See page 3-5 of the owners manual - the section on "HOW TO USE REMOTE KEYLESS ENTRY SYSTEM".
Old Sep 16, 2004 | 02:40 AM
  #248
KPierson's Avatar
KPierson
Yep, that is normal. All of the Zs and Gs do that. After you hit the unlock button you have 60 seconds until the doors relock. I guess this is in case you accidently unlock the car without knowing, or if you unlock it and then run back inside and forget to come back.
Kevin
Old Sep 16, 2004 | 07:31 PM
  #249
sal1's Avatar
sal1
Thanks for your reply. I guess I never read that.
Obadabot
Jun 18, 2023 11:31 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
