Is there a crossover module in the door?
Old Feb 13, 2020 | 04:39 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
Default Is there a crossover module in the door?
I see there's a tweeter in the door and everywhere referees to the lower 6 1/2" speakers as "woofers". I picked up some infinity reference speakers that have the tweeters in them.
So is there a crossover module in the door or someplace that is splitting the sound between the "woofers" and the tweeters.
I would like to locate the wire that comes straight from the head unit for the front sound and wire that directly to the infinity speakers.
I installed the head unit myself so I know there's only four wires, 2 positive and negative, that go to the fronts. Where do those wires end up in the door?
Old Feb 13, 2020 | 11:56 PM
813_350Z's Avatar
813_350Z
In my 05 enthusiast, at least, there is no crossover in the door. I have two wires that run to the speakers and two more that run up to the tweeter. I assume all four come straight from the HU
Old Feb 14, 2020 | 02:53 AM
Bmsluite's Avatar
Bmsluite
5 Year Member
Well I'll tell you this, all four of those wires DO NOT come from the head unit. Somewhere there is a split. I had to hard wire my head unit from Nissan schematics as the original owner had screwed ip the wiring back there. There MUST be a crossover and I want to find it.
Old Feb 14, 2020 | 05:14 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Have you checked the FSM wiring schematics?
Old Feb 14, 2020 | 07:42 AM
Bmsluite's Avatar
Bmsluite
5 Year Member
I'm going to call Crutchfield and get them to email me the schematics. This is the best I could find online this morning but it contains no index and its a pretty shoddy schematic as is.
Old Feb 14, 2020 | 07:58 AM
jhc's Avatar
jhc
General & Tech Moderator
Hey man,
Don't use a very old cross-over that was designed for the cheesy Clarion/Bose setup, (it was designed for 2 ohm speakers). Use the one that came with your kit, sure, it's slightly more effort. You will thank me later.
Old Feb 18, 2020 | 12:24 PM
ajpasa's Avatar
ajpasa
Hey, no x-overs at the doors.
If you have an amplified system, like Bose, the wires go to an amplifier, and then to the door/back panel speakers. Note that in this case, the signal from the radio is of high impedance / low power (RCA level).
Br,
Al.
Old Jul 29, 2023 | 11:08 AM
vsndesigns's Avatar
vsndesigns
Old model, definitely switch it out for one that matches your speaker specs.
marcelz
Feb 11, 2010 11:53 PM
Gilley
Nov 9, 2006 11:15 AM
Z4Zoro
Jun 8, 2006 10:36 AM
jbenedict
Dec 27, 2004 12:59 PM
