Screen placement in a base model
Old Mar 24, 2004 | 07:58 AM
SilverstoneZ's Avatar
SilverstoneZ
Default Screen placement in a base model
I am looking to get a screen installed in the navi location of my car. Are there any certain screens that I should be looking at that fit better and what is the max size I can fit without having issues with the compartment opening. Thanks.
Old Mar 24, 2004 | 08:48 AM
ares's Avatar
ares
Veteran
do you have an 04?
from what I understand thats not really doable...
03s can remove the storage bin from the unit, and the remaining hole fits a 7" screen perfectly.
from there farenheit fits in its case, and xenarc fits out of its case, both 7". not sure that farenheit has TS or VGA options, though they may. there are a bunch of others that fit and are cheaper, they came around after I researched my screen so I dont know about them.
Old Mar 24, 2004 | 09:08 AM
zpylot's Avatar
zpylot
I used the 7" Xenarc VGA Touchscreen. I have a 2004 Roadster non-nav. I had to buy the 2003 non-nav compartment. The Xenarc fits perfectly when you take it out of it's case. Here are some pictures of it in action.
http://www.kcdog.org/car/
FYI: The 2003 non-nav compartment door is a shade lighter than the 2004 door.
Old Mar 24, 2004 | 09:11 AM
zpylot's Avatar
zpylot
I've got a 2004 Roadster non-nav. I used the Xenarc 7" VGA Touchscreen. I had to buy a 2003 non-nav compartment to mount the Xenarc on. I took the Xenarc out of it's case. Here are some pictures I took of it after the install.
FYI: The 2003 non-nav compartment door is a shade lighter than the 2004. When the door is closed you can tell it's different. But it's mostly going to be open so I don't mind so much.
Old Mar 24, 2004 | 09:12 AM
zpylot's Avatar
zpylot
Sorry for the double post, I thought the first got lost. This site is having some problems.
Old Mar 24, 2004 | 11:13 AM
SilverstoneZ
Awesome thanks. I have an 03 by the way.
Old Mar 24, 2004 | 11:15 AM
saint01's Avatar
saint01
if you don't mind me asking, how much did you pay for everything that you needed? i am looking to do this with my 03 and have just started getting pricing on things.
Old Mar 24, 2004 | 12:24 PM
bigern1970's Avatar
bigern1970
Default Re: Screen placement in a base model
Heres mine with an eclipse deck its a 5.6,7 will cost you alot more , I did my deck and screen for 700.00 . thanks heres a pic
Old Mar 24, 2004 | 12:25 PM
bigern1970's Avatar
bigern1970
sorry heres the pic
Old Mar 24, 2004 | 12:26 PM
bigern1970's Avatar
bigern1970
Default Re: Re: Screen placement in a base model
Old Mar 26, 2004 | 08:59 AM
shaneotool's Avatar
shaneotool
Check this screen out - it looks simple to install. It is a double din size so it just goes where the stock radio goes. It has the screen and dvd player in one box.
http://www.crutchfield.com/S-8Pptln7...=0&cc=01&avf=N
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
