Thumping noise from JL bass 10 W6 V2
Old Apr 7, 2004 | 10:12 PM
pearl430's Avatar
pearl430
Default Thumping noise from JL bass 10 W6 V2
help please
everytime i turn on stereo the thumping noise from the JL bass is very loud
is there anyway to get rid of this noise or turn it down????
thanx
Old Apr 7, 2004 | 10:29 PM
wren57's Avatar
wren57
um... its a subwoofer, thats what its supposed to do... are you looking to make the sub less loud? If so, what headunit do you have? My alpine has built in sub controls; if yours doesn't, most amps come with a **** you can attach to control bass...
Old Apr 7, 2004 | 10:33 PM
pearl430's Avatar
pearl430
not that noise
u know when u first turn it on it blast a loud noise
very loud and abnoxious 1 sec noise
like a big boom
Old Apr 7, 2004 | 11:18 PM
quangquoclu's Avatar
quangquoclu
Newbie
try turning down the gain cuz it shouldnt be doing that at all... if that doesnt work then its your deck or install...
Old Apr 8, 2004 | 03:30 PM
soundcreator's Avatar
soundcreator
what kind of headunit do you have?
sounds like that you have a stock headunit and have a problem with remote. if that is the case, try to get hands on remote turn-on relay.
it should solve your problem.
Old Apr 8, 2004 | 05:52 PM
skitzo's Avatar
skitzo
if you get a big thump when your amp kicks on try turning down the gain, if that doesnt work it sounds like a bad install check your grounds
Old Apr 9, 2004 | 08:26 PM
pearl430's Avatar
pearl430
Thanx everyone
problem solved
the guy at circuit city installed the remote wire wrong
he probably hooked up the remote to the small amp of the sub somehow when ever ignition is on the amp also goes on even the alpine deck is off
so when i turn on the deck the amp already on so it kick in a loud noise - and that is badddddddd
so they had to rerun the new remote blue wire straight from the alpine deck and it stop
thanx again everyone, it was a loudddddddd clik when turn on
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
