Custom install for stock sub location w/pics
Old Apr 12, 2004 | 12:20 PM
240DRIVEN's Avatar
240DRIVEN
Default Custom install for stock sub location w/pics
I didn't like how it was sounding with the empty compartment behind the sub to i decided to seal it off. Also dynamatted the rear hatch area. It sounds much better now. Here's some pics:
Attached Thumbnails Custom install for stock sub location w/pics-install-034.jpg
Old Apr 12, 2004 | 12:25 PM
240DRIVEN's Avatar
240DRIVEN
made a box around the seat belt assembly
Attached Thumbnails Custom install for stock sub location w/pics-install-0222.jpg
Old Apr 12, 2004 | 12:28 PM
240DRIVEN's Avatar
240DRIVEN
the box was filled with great stuff around the edges and bottom to give it some substance. Eventually I dynamatted the entire compartment.
Attached Thumbnails Custom install for stock sub location w/pics-install-029.jpg
Old Apr 12, 2004 | 12:30 PM
240DRIVEN's Avatar
240DRIVEN
more great stuff...
Attached Thumbnails Custom install for stock sub location w/pics-install-037.jpg
Old Apr 12, 2004 | 12:32 PM
240DRIVEN's Avatar
240DRIVEN
the gapping whole in the back was also blocked off with more cardboard and great ****...
Attached Thumbnails Custom install for stock sub location w/pics-install-025.jpg
Old Apr 12, 2004 | 12:34 PM
240DRIVEN's Avatar
240DRIVEN
and finally the mat...
Attached Thumbnails Custom install for stock sub location w/pics-install-041.jpg
Old Apr 12, 2004 | 12:35 PM
240DRIVEN's Avatar
240DRIVEN
here's the dynamat around the seat belt assembly box..
Attached Thumbnails Custom install for stock sub location w/pics-install-043.jpg
Old Apr 12, 2004 | 12:36 PM
240DRIVEN's Avatar
240DRIVEN
panels back on...
Attached Thumbnails Custom install for stock sub location w/pics-install-049.jpg
Old Apr 12, 2004 | 12:37 PM
240DRIVEN's Avatar
240DRIVEN
and back to stock!
Attached Thumbnails Custom install for stock sub location w/pics-install-050.jpg
Old Apr 12, 2004 | 12:41 PM
Big Sexz's Avatar
Big Sexz
Is that a 12? BTW Nice. Few more questions.... How much Dynamat did you use? And how much was it? I'm using this Thunder Mat stuff off ebay that is working pretty well. I must say that yours look much cleaner then mine does. I had to cut little strips so I could get down in all the groves. Did you pull the carpet and get under there? In doing that the road noise dramatically decreased. Seriously nice job!
Old Apr 12, 2004 | 12:46 PM
240DRIVEN's Avatar
240DRIVEN
No, 12 wouldn't fit.
Old Apr 12, 2004 | 12:49 PM
Big Sexz's Avatar
Big Sexz
please see above edited post. Sorry about that.
Old Apr 12, 2004 | 12:54 PM
240DRIVEN's Avatar
240DRIVEN
I bought the dynamat from Etronics.com. Bulk pack (30 sq.ft.) 150$ delivered. It came the next day, they are quick. It ended up being just the right amount I needed, right down to the sq inch! I did pretty much from the rear speakers all the way back and the entire sub compartment. It is not that hard to install but takes time! I worked all day from 9 am to about 12 midnight. I'm a little disappointed that i still hear alot of road debris (gravel and sand) in the rear. I bought some vb-1x for that though, that will be my next project. Anyway, you asked about the rear carpet. Ya, you have to remove pretty much all the paneling.
Old Apr 13, 2004 | 04:41 AM
Big Sexz's Avatar
Big Sexz
That's a pretty good price. Let me know how the vb-1x stuff works out. I'm guessing that is a spray on product?? As for the carpet, I was referring to the removal of the seats and pulling the actual carpet off the floorboard. Once I did that, BIG difference. That is easily something you can do at a later date.
Old Apr 13, 2004 | 05:03 AM
dimitri's Avatar
dimitri
How does it sound???I have done something similiar with the great stuff also dynomat and a pioneer free air and sounds great ....but as u say alot of consuming work.But well worth it because we get to use the factory location.
Old Apr 13, 2004 | 05:27 AM
240DRIVEN's Avatar
240DRIVEN
Oh ok, no i didn't dynamat under the seats but i have heard from others it does make a big difference. Are there any threads on here on how to remove the seats and carpet? I'll let u know how the vb-1x turns out.
Old Apr 13, 2004 | 01:39 PM
Dissident's Avatar
Dissident
How much does the xtreme dynamat weigh? I can get .5 lb/sq foot second skin for 40 sq ft for $162 delivered and was gonna use that instead...
Old Apr 13, 2004 | 03:11 PM
BlkTN04Z's Avatar
BlkTN04Z
Great job I did the same.
Also I used poly fill in mine and it helped alot.
Later
Old Apr 13, 2004 | 06:33 PM
dbsinc's Avatar
dbsinc
Default This is where I had my problems
This looks great!! When I did this I had the hardest time getting my apline on the bracket. It looks like you made an additional wood bracket to attach the speaker to, then attached the two brackets. Is that correct? Could you give a detailed account of the creation and mounting of this second brackett. Also if you could take some closeup pics of it it would be great. I thought about adding an additional bracket but I thought the speaker cover wouldn't fit therefore negating the stock look.
Originally posted by 240DRIVEN
panels back on...
Old Apr 13, 2004 | 08:36 PM
JasZ's Avatar
JasZ
240DRIVEN,
That is friggin' sweet. How does that sound without a separate box?
How difficult was this to do?
I'd like to get a custom bracket for dual 8" subs for that compartment.
