Monitor Installation.. 12V Power wiring
Old Apr 12, 2004 | 07:19 PM
georgyo's Avatar
georgyo
Question Monitor Installation.. 12V Power wiring
Hello,
I am currently installing a Farenheit T-70001MHR.
My question is this....... Which Hot wire in the harness did you use to power your monitor?
I read one post that indicated using the light green wire on the far left of the "big" plug (factory plug).
This translates to being the red (hot) wire which is soon to be in use for my aftermarket HeadUnit.
Since my head unit will draw 14V max and the LCD monitor draws 7.9 V max, I am wondering if connecting them both to this wire would draw too many amps,.....and blow the fuse in the panel?
Another wire might work, but not sure which one.
Just start testing with VoltMeter? Well, maybe, but I would like to get it right the first time.
Am I better off to just run a seperate 12V power wire from the battery\ or a distribution block to power this LCD monitor?
Any help would be appreciated!
Thanks!
Old Apr 13, 2004 | 03:45 AM
aalzuhair's Avatar
aalzuhair
Well I used the wire the described in your post, and I'm using the stock Boss HU and a 7" LSD with touch panel and it works fine fro about 1 month now.
Az
MAsSIVrOOM
Oct 20, 2023 10:50 AM
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
