My Newbi Install
Old Apr 28, 2004 | 06:08 PM
Th3Cleaner's Avatar
Th3Cleaner
Talking My Newbi Install
Window tint ... done by DriveInAuto (Pueblo Co)
Temp Plate :-)
There it is with a little phone bill to the older brother that has been doing this stuff for almost 20 years
He gave me some help placing things..
The install was my doing, its my first it sounds very very very good now after a day of tweaking and tuning.
total cost somwhere near 1000.00
I won't show the sub it temp.
maybe after its done.
Old Apr 28, 2004 | 06:24 PM
kendoll's Avatar
kendoll
WOW I am envious, there is something to be said for the do it yourself high. Congrats. BTW does tyour brother want to give any pointers to the masses.
Old Apr 28, 2004 | 06:57 PM
Th3Cleaner's Avatar
Th3Cleaner
I only put holes through things I knew I could replace if needed.
Like that window ABS piece, and the glovebox pieces.
I put a Small 10" in the back with the Sub pointing to the back window, it sounds realy sweet tight bass but it looks like somthing that would go in a ford pickup :\ so I have the local "small shop" trying to find me somthing for the Z-Bar area.
Old Apr 28, 2004 | 07:03 PM
zand02max's Avatar
zand02max
Nice install neighbor
Old Apr 29, 2004 | 05:27 AM
Big Sexz's Avatar
Big Sexz
When I saw the first pic I must admit that I was a little scared with the dynomat flapping around. But as I kept scrolling it looks great!! I just did a complete system make over myself and can totaly relate to the satisfaction of a job well done....especially when it works
Old Apr 29, 2004 | 06:21 AM
Dream2Reality's Avatar
Dream2Reality
Any shots of the speaker install process, but from further away? I need a full shot of the bare door.
Old Apr 29, 2004 | 07:00 AM
Th3Cleaner's Avatar
Th3Cleaner
I knew there had to be somone close to me on this forum
heheh...
Old Apr 29, 2004 | 07:02 AM
Th3Cleaner's Avatar
Th3Cleaner
I will get that for you, I need to tear down the passanger door completly and I will take pics, The spacer I am using is a hair to tall and the door speaker on the passanger side only pops when the bass kicks, not due to over loudness, its set at 140Hz so there shouldnt be to, to much bass, but the fact i can see it hitting the door panel.
Old Apr 29, 2004 | 12:36 PM
Dream2Reality
How big is your spacer, that now it hits the panel?? I'm putting 8's in the doors, so I'm trying to figure out how I'm gonna do that...muahaha. Maybe sand down one side so it's angled differently? Thanks in advance.
Old Apr 30, 2004 | 01:00 PM
Th3Cleaner's Avatar
Th3Cleaner
door spacer may be close to 1.5" on top of door and padding.
its a real trick, been raining couple days here in colorado, so I havnt had a chance to get car out of the garage and play.
jeep goes through mud better :-)
Old Apr 30, 2004 | 03:54 PM
neur0sis's Avatar
neur0sis
Man, lookin good!
You're like the 4th person I have seen with those Type R's in the door. I tried for like 5 hours to install those so they didn't hit the window, and the door panel would go back on correctly, and had no luck!
I used the stock speaker as my "spacer" and the magnet assembly was about 1/16th an inch away from the window inside, and the door panel would have been TOUCHING the speaker surround itself. Did you do anything special to install those?
Old Apr 30, 2004 | 06:35 PM
Th3Cleaner's Avatar
Th3Cleaner
I went to the local audio shop and they sold me a pack of 1" spacers (18.00), look at the top image I placed sticky weather striping around both side of the spacer (Lowes 7.00). Next I took the screen from the Type R speakers and poked them out ( brother showed me this trick) I took the speaker ring and turned them upside down and placed them on that one inch spacer.
so now its almost 1.5" spacer.
Then mounted the speakers using a bolt drill (reason: so i didnt slip a "screw" through the speaker)
Although I drilled before the speakers were set in, that was my reason if I were drilling while speakers were in.
I marked where the door panel was hitting the speaker spacers on both sides, I then took small wire cutters and cut the inside of the door panels (took 3 min). Next as I mention above the spacers made the "door panel original speaker screen" poke out on the bottom, there is a small plastic "molded" clip I cut that one off. and thats it !!@
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
