Sirius problems - has anyone experienced this yet?
Old May 16, 2004 | 05:24 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default Sirius problems - has anyone experienced this yet?
I have a weird, intermittent problem that I can't seem to figure out - hoping maybe someone else has experienced it too!
I have the Kenwood 7015 with the kenwood Sirius tuner - in the car for about 3 weeks now. For the last week, when listening to Siriud (regardless of the channel), it only plays out of the drivers side speakers! If I cycle to CD, DVD, or the regular radio tuner, it plays in full stereo as it should. Occassionally, shutting the headunit off completely, then powering back on solves it, but 9 times out of 10 it does not. It is totally randowm, as has nothing to dow tih hitting bumps in the road, turning one way vs the other, etc. Sometimes it works as it should, but most times it does not.
Yesterday I brought it down to my installer to ahve him look at it. He swapped the Kenwood brain, and it worked until this morning, when it started the same thing all over again?
From what he tells me, the cable that connects the Tuner to the headunit is the same type as used on a CD changer? Do these ever go bad?
Any feedback would be great - I hae a long trip to IAS scheduled this week, and would love it to be 100% operational!
Thanks guys
Adam
Old May 16, 2004 | 06:06 AM
mgk65's Avatar
mgk65
It does sound like a short in the cable from the sirius tuner to the kenwood or the sirius tuner since you have replaced the HU.
No way to really know without swapping the cable and if the problem remains, then the Sirius tuner.
Old May 17, 2004 | 09:15 AM
Z1 Performance
Former Sponsor
I dd not replace the headunit - I replaced the Sirius tuner "brain"
Old May 17, 2004 | 09:54 AM
SizongZ's Avatar
SizongZ
I have the same head unit with sirius for almost two months now and I haven't had this problem. The only thing I can think of is check the wiring
Old May 17, 2004 | 12:40 PM
MonkeyBoy's Avatar
MonkeyBoy
Sounds like the "brain" is either bad, or the wiring is suspect. Check the wiring first, if not, send the unit to where you bought it and get it replaced.
Old May 17, 2004 | 12:54 PM
Z1 Performance
Former Sponsor
yeah we replaced the brain already so going to swap cables tomorrow...hopefully its not the head unit itself
Old May 17, 2004 | 07:57 PM
skitzo's Avatar
skitzo
Obvious question: Did you check the fader/balance settings, that head unit keeps individual audio profiles for each component (sirus, tuner, dvd, music keg, etc..)
Old May 18, 2004 | 07:24 AM
Z1 Performance
Former Sponsor
yep - checked it. Like I said, it sometimes works fine, sometimes doesn't
Old May 18, 2004 | 08:01 AM
350zluvr's Avatar
350zluvr
You don't by chance have the Bose system in your car do you?
Old May 18, 2004 | 08:30 AM
Z1 Performance
Former Sponsor
nope
Old May 18, 2004 | 12:27 PM
Zracer03's Avatar
Zracer03
It would have to be the wire that runs from ther tuner to the HU. Yes, it is the same cable that the CD changer uses. My cable runs from the HU to the Tuner, and then another cable of the same type from the Tuner to the changer. Mine works fine, but if the speakers are cutting out only through Sirius, then the cable is either loose, or bad.. The only other thing I can think of is if you have AMP wiring along the same run as the cable. Hope you get it solved.
Old May 18, 2004 | 01:09 PM
Z1 Performance
Former Sponsor
no amps in the car yet, so must be the cable..will get it replaced.
I was thinking the same thing, just trying to rule out the hu
Adam
Old May 18, 2004 | 02:45 PM
shaun03z's Avatar
shaun03z
i have the same headunit and tuner, no problems yet, just some high quality stations and some low quality sound stations.
Old May 29, 2004 | 04:25 PM
Z1 Performance
Former Sponsor
well, I have since replaced the Sirius tuner brain, and the cable connecting the brain to the headunit, and still no good
guess my headunit is bad afterall
Old Jun 6, 2004 | 07:59 AM
Z1 Performance
Former Sponsor
bump - any other options before I go and swap hu's?
Old Jun 17, 2004 | 06:11 PM
Z1 Performance
Former Sponsor
anyone?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
