Sound System "Break in?"
Old Jun 27, 2004 | 08:35 PM
Jergens's Avatar
Jergens
Default Sound System "Break in?"
Hey stupid first sound system question... is there a breakin period for speakers? I haven't really pushed them more than 2 minutes goofing around showing the system to my buddies, but I was curious if anything needs to seal or warm up/ fill out?
~Josh
Old Jun 28, 2004 | 02:14 PM
murrman100's Avatar
murrman100
Not unless you are using some type of glue, resin or epoxy that is still drying.
It does take a little time to adjust the sound to your taste.
Old Jun 28, 2004 | 02:47 PM
imntcrzy's Avatar
imntcrzy
there is always a break in period for speakers.... if you are using stock system or blose it may be minimal..... but all speakers and voice coils will have a break in period. i.e. focals out of the box and focals after 3 months are a completely different animal.
Old Jun 28, 2004 | 02:52 PM
murrman100's Avatar
murrman100
I did experience something like that. They sounded a little different from a few months ago.
I took the car back to the shop and they told me that the speakers were blown.
Old Jun 28, 2004 | 02:57 PM
imntcrzy's Avatar
imntcrzy
ummmm...... blowing the speakers is one thing. I would turn it down a notch.
but yes as I said all speakers do break in. The spider tends to loosen up and and get smoother. I think there is a slight difference between breaking in and just breaking it
Old Jun 28, 2004 | 07:18 PM
BriA5's Avatar
BriA5
You deffinately need a break in period. The surrounds for the cones will loosen over time, changing the sound of the speakers. I say don't go crazy on them for a little while to let them break in.
Old Jun 28, 2004 | 09:14 PM
murrman100's Avatar
murrman100
I check around and imntcrzy is correct. Depending on the type of speakers and amps that you do have, there is a set break in period.
The higher end amps/speakers require different times to adjust.
Good thing that I have extended warranties.
Time to fry some more subs.
Obadabot
Jun 18, 2023 11:31 PM
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
