Sound Quality of AVX2494
Old Aug 15, 2004 | 01:22 PM
DTM323's Avatar
DTM323
Default Sound Quality of AVX2494
Just curious how much the addition of this headunit will improve sound quality, I getting JLs installed as well probably with a 4 channel amp...how will all of this sound/work together?
Thanks!
Old Aug 15, 2004 | 09:48 PM
murrman100's Avatar
murrman100
Default Re: Sound Quality of AVX2494
Thanks!
I have the avx2404 in the Z and the avn2454 in the Altima.
I had the "Blose" in both cars.
It actually sounds better in the Altima than in the Z.
Anything that you get is better than the "Blose".
I've had Alpine and you will not be dissapointed with Eclipse.
Don't skimp on the amps or speakers either. Make sure that you get good quality stuff to back up your head unit.
Good luck!
Bose
Old Aug 16, 2004 | 12:24 PM
RANDY350Z's Avatar
RANDY350Z
The AVX 2494 doen't have pre-outs right?
What would you use to connect a 4 channel amp and a 1ch mono amp for a sub?
Old Aug 16, 2004 | 01:03 PM
murrman100's Avatar
murrman100
The avx2404 and the avn2454 both have pre-outs. I don't know why the avx2494 wouldn't have them.
Eclipse's web site has nothing next listed in the specs.
I'll call and ask my Eclipse dealer.
I was thinking of trading up to that model anyway.
Old Aug 16, 2004 | 01:41 PM
gsarch's Avatar
gsarch
I just had an AVX2494 installed in my 350z and it does not have preouts. I'm using line out converters and a 4 channel Memphis amp. I'm having the headunit power the rears and I'm using the amp to power the fronts and the sub.
I've got it hooked up to Focals, and it sounds pretty good. I have to admit I haven't really compared it to anything, but it sounds good enough for my tastes and it's certainly 1000's of times better than the blose.
The HDD works really well when there is CDDB information for the disc your recording. If not you have to manually enter in the song titles/cd info which can be a pain. It took me about 10 minutes to enter in a CD which wasn't in the database.
The database is supposed to be updatable, but an eclipse tech told me that it's probably not going to happen unless they sell some more units.
The other problem i have is that there are only 6 radio presets. You can have the autoprogram run and it will give you another 6, but you cannot save those.
Other than those two issues, I really like the headunit. DVD quality is great, and the interface is easy to use. If you have any questions, or need some pics of what it looks like let me know and I'll post them.
Also, on a sidenote, I originally had the focals hooked up to the stock bose head unit and putting in the Eclipse DID make a difference in sound quality. However, the lack of preouts don't make it the ideal SQ headunit.
-David
Old Aug 16, 2004 | 02:50 PM
murrman100's Avatar
murrman100
-David
It looks like Eclipse goofed that one up. You would think that this highend head unit would have the opposite with no internal amp and high volt pre outs.
Does the 2494 have 5.1 surround decoder?
Old Aug 16, 2004 | 06:56 PM
RANDY350Z's Avatar
RANDY350Z
If you can post some pics of it installed and even some of its screen pics--such as sound field dsp, lps, eq, would be great!
I don't understand either why this doesn't have pre-outs.
Does it have an Elan connector for a cd changer? ( not that you wuld really need one since it is HDD)
Old Aug 16, 2004 | 07:01 PM
RANDY350Z's Avatar
RANDY350Z
I also hope Eclipse comes out with a seperate Nav unit to connect with this unit, I talked to my local shop and they said not any time soon. ( I even called Eclipse and they said no)
Old Aug 16, 2004 | 07:42 PM
maximadave's Avatar
maximadave
Car audio companies do that to hit at certain price point (speakers and amps too). The car audio business is very competitive
Old Aug 16, 2004 | 07:43 PM
maximadave's Avatar
maximadave
Car audio companies do that to hit a certain price point (speakers and amps too). The car audio business is very competitive between manufactuers.
Old Aug 16, 2004 | 09:05 PM
gsarch's Avatar
gsarch
The AVX2494 doesn't have a 5.1 decoder, I believe only the 2404 does.
You can hook up to two additional CD Changers to the head unit. I believe they are "plug and play" so if you don't have the CD changers installed, there is no button to press on the screen.
Also, the Head Unit comes with a Nav Attenna which I had installed, even though there is currently no Nav system for the AVX2494. It's only function is to keep the clock accurate, but I talked with an eclipse rep and they told me that if they were to make a NAV ready HDD for this unit, you could swap out the existing HDD and have a fully functional NAV system.
I will post pics tomorrow.
-David
Old Aug 17, 2004 | 07:21 AM
RANDY350Z's Avatar
RANDY350Z
Thanks !
Old Aug 17, 2004 | 08:07 AM
MacAlert01's Avatar
MacAlert01
I'm assuming Eclipse did not put pre-outs on the 2494 so you can integrate a new HU with the stock speakers and not have to add an additional amp. I know when I added an Eclipse HU to my Blose in my maxima, the sound was completely crap because I have to convert from pre-out to line level (i think). So as I stated originally, I think it was to have the HU integrated w/ stock speakers.
Old Aug 19, 2004 | 12:37 PM
RANDY350Z's Avatar
RANDY350Z
Any PICs
Old Aug 19, 2004 | 12:44 PM
murrman100's Avatar
murrman100
Its not avx2454 but ....
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
