Engine Noise
Old Aug 30, 2004 | 05:09 PM
zand02max's Avatar
zand02max
Default Engine Noise
Here's what I have:
Pioneer AVIC-N1 (DVD/NAV)
Pioneer 6 disc changer
Kicker RS Mids/Tweets, Focal 165K Poly's mids,
(2) RF 12" HX2's in custom fiberglass enclosure in tire well
RF Power 800.4
RF Power BD1000
Pyle 3 Farad Capacitor
Optima Yellow Top Battery
Top of the line wires/RCA cables.
I have placed 2 noise filters and it got worse. Anyone know the fix to this? The install shop does not have a clue and wants me to leave it again all day this Sat. WTF
Ground and hot wire are properly installed.
I didn't pay over $4000 to listen to my DAMN engine through the DAMN speakers. This is B.S.
Pisses me off!
Old Aug 30, 2004 | 05:15 PM
swoobyz's Avatar
swoobyz
Default Re: Engine Noise
Originally posted by zand02max
This is B.S.
Pisses me off!
Ah, the dreaded ground loop problem!
How is the optima battery connected to your system?
What if you temporarily tried to power the system from the main battery?
Do you hear the noise in speakers coming from both amps?
Are the RCA cables shielded or twisted pair?
Where did you place the noise filter?
On the 12V line, or on the RCA line?
Old Aug 30, 2004 | 05:22 PM
zand02max's Avatar
zand02max
Default Re: Re: Engine Noise
How is the optima battery connected to your system? I believe through the capasitor.
What if you temporarily tried to power the system from the main battery? might try that
Do you hear the noise in speakers coming from both amps? No, just the mids/highs amp
Are the RCA cables shielded or twisted pair? shielded
Where did you place the noise filter? right after the Nav unit via RCA cables/
Hope this helps
Old Aug 30, 2004 | 07:08 PM
MSGarrett1's Avatar
MSGarrett1
The best RCA cables are a simple braided/twisted pair. RCA shielding actually functions like a noise antenna. This could be your problem. In fact, I know many a system, where people purchased "high end"/not cheap noise shielded RCA cables, and had noise. They simply replaced the RCA cables with twisted pair ones, and the noise went away.
I use Rockford Fosgate signal wires. Check out this link:http://www.rockfordfosgate.com/ezcom...e.asp?key=1682 There are many others you can buy that are also simple twisted pair technology (not shielded), and result in noise-free music.
Old Aug 30, 2004 | 07:54 PM
zand02max's Avatar
zand02max
thanks. The folks that sold me the wiring, said twisted was not the way to go. Typical stereo shop answer, their product is always the best,
Old Aug 30, 2004 | 09:57 PM
bastard's Avatar
bastard
If the noise you are hearing is like a high-pitched whine that gets higher pitched as engine revs go up, it's likely from a ground loop (it's alternator noise). I am using relatively cheap braided Fosgate RCA cables and I have zero noise. Some (so I've heard, anyway) cables do not have the outer part of the RCA plug connected to the shield, which can result in noise being introduced. I believe the noise on the shield is subtracted from the signal on the inner conductor by the amplifiers to remove the noise--this may be a "balanced" input, I don't remember exactly. If the cables you are using have the shields not connected to the "cuff" of the RCA connector, then there is no noise signal to subtract from the actual program material, and well, 1 - 0 is still 1, so the noise will remain.
Where are your grounds connected? Make sure all grounds you add are part of the actual unibody of the car. Also make sure your RCA lines are not run near any power cables (or grounds) or fans or computers or anything like that. It is okay to cross power cables with signal cables as long as they don't run parallel, only perpendicular.
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
