Kenwood DDX7015 install questions
Old Oct 9, 2004 | 01:23 PM
Z'd Up's Avatar
Z'd Up
Default Kenwood DDX7015 install questions
I'm ready to get the headunit installed this weekend. I do however, have some questions.
#1 where would be the best location to connect the illumination (orange wire)?
#2 Is it okay to connect the Music Keg to the CD changer connector?
#3 For those with the DSP (KDS-901), Where did you mount it?
Should it be in a space with some ventilation?
Thanks in advance for you help!!!
Old Oct 13, 2004 | 10:20 PM
BLACKZTRACK's Avatar
BLACKZTRACK
#2 Is it okay to connect the Music Keg to the CD changer connector? Yes it is
Old Oct 14, 2004 | 06:45 PM
stu46's Avatar
stu46
1. to the illumiation wire. don't know what color it is. Go to a stereo shop and look at a wiring harness for the car. on the package will list all the colors for the wires needed.
Old Oct 14, 2004 | 09:11 PM
DaTaSPiKe's Avatar
DaTaSPiKe
1. The illumination wire is Orange, on both the deck's wiring and on the wiring harness that is made for the car.
Like he said above, get the wiring harness and save yourself hours of trouble.
Chris
Old Oct 14, 2004 | 10:31 PM
Z'd Up's Avatar
Z'd Up
Thanks for the repies! - will test it out this weekend.
Completed install probably will not happen until mid next week -Metra kit now in transit (eta oct. 18th)
Old Oct 14, 2004 | 11:08 PM
ExtaZ33's Avatar
ExtaZ33
Can you post pics when you're done? I haven't seen one installed, and I was hoping to get that unit.
Old Oct 23, 2004 | 01:20 PM
vantage350z's Avatar
vantage350z
i mounted my DSP under the clove box. the unit comes with 17 feet of optical cable, so you can pretty much put it wherever you want. this also eliminates the need for long RCA cables to the amps. if you want you could mount it right next to your amps..
make sure you dont bend the optical cable to much or you will damage it.
Old Oct 24, 2004 | 12:54 AM
Z'd Up's Avatar
Z'd Up
Thanks for the reply/feedback
Almost done - I got the HU installed and wired to go today. I cannot believe all the wires fit in the little space behind the HU and white box. Also, ran new speaker wires through the doors and rear; connected the crossovers to the door speakers tweeters.
watched a few minutes of a DVD tonight before calling it the night.
I really like the screen tilt angle feature.
The stock NAV and DDX-7015 screens look tight at night especially looking from the rear window.
Will power up the amps (4*, Sub, and CTR channel) tomorrow.
Old Oct 24, 2004 | 02:50 PM
35oZephyR's Avatar
35oZephyR
Post some pics!
I was interested in the 7015 as well. How "angled" can you get the screen to sit?
Workshop12
Mar 23, 2020 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Suffolk350z
Sep 13, 2015 02:43 PM
