Mobile Video System Finished
Old Oct 12, 2004 | 01:08 PM
leolufse's Avatar
leolufse
Default Mobile Video System Finished
Whoa boy, I finally finished the mobile video system in the Z. It took exactly 3 months.
Alpine CDA-9835 HU
Alpine DVA-5210 DVD
Alpine TUA-T020 XM
Sony XVM-H65 Monitor
MB Quart PCE 216 front components
MB Quart DKE 113 rear fill
PPI PCX 4125 AMP
(2) Image Dynamics 8V.3D2 subs.
All pics here: http://peachstateposse.com/ipw-web/gallery/album31
Old Oct 12, 2004 | 01:52 PM
buletman's Avatar
buletman
Awesome. I'm Curious, I see all of your wires going down into your sub enclosure, or is it an illusion, and they are going down, but not into the enclosure itself?
Old Oct 12, 2004 | 01:58 PM
leolufse's Avatar
leolufse
Yeah, I'm bad at taking pics. There is actually an amp rack that sits on top of the sub box and all of the wiring comes up through the floor of the car, and the underside of the amp rack. The amp rack is screwed to the top of the sub box and there is just dead space under there.
Old Oct 12, 2004 | 02:13 PM
buletman's Avatar
buletman
Awesome, I want to do pretty much EXACTLY what you did, except I would like to use fiberglass, and I have two amps, but I think they should both fit (500/1 and 300/2).
Did you record the Cu. Ft. of the enclosure? I need ~1.34 for my 10W7, and I took some measurements and found I would need to use a lot of the under strut area to accomodate (sp?) this.
Old Oct 12, 2004 | 03:44 PM
leolufse's Avatar
leolufse
The box I made for the 2 8" ID subs is a total of .7cf. The owners manual wanted .35 for each one, so I'm right on. The box part of the box is about 23"Wx11"Hx8"D (outside dimensions) to achieve this. I had enough room to make the box about another 8" deep. That would give you enough internal volume for that sub. Then just mount the amps to the top of the box that protrudes into the hatch area and you're good to go.
Old Oct 12, 2004 | 03:59 PM
buletman's Avatar
buletman
Thank you that is exactly what I wanted/needed to know/hear.
:-D
Old Oct 13, 2004 | 09:34 AM
motown's Avatar
motown
Wow, man, that looks really great! How's the SQ with the Quart's? I've always found their tweeters to be too bright, but that's just me. Your install looks great! I didn't bother taking pix of mine, but that's just b/c I'm lazy. Just curious, are you using any Dynamat anywhere? My car's turned into a real rattle-trap with my sub. Again, kudo's on the install!
Old Oct 13, 2004 | 12:22 PM
leolufse's Avatar
leolufse
Thanks for the compliments. I'm a huge fan of MB Quarts, I recommend and install them all the time. They are metallic tweets which will always be more "harsh" than silk tweets. But my opinion is that you can easily make a harsh tweet more laid back, but you can't make a laid back tweet bright. I have the tweets set at negative db attenuation to alleviate the brightness and increase the mid range prominence. They are a great set of components for the $$. Mid bass is very impressive and the sound stage is pretty easy to achieve in the Z using the stock woofer and tweeter location and a bit of time delay adjustment on the HU. If you go with the MBs, bring on the power. I'm running them at 125 RMS and they love it.
Old Oct 13, 2004 | 01:29 PM
buletman's Avatar
buletman
I'm waiting to install my set of Focal 165 K2Ps...I've heard they are probably in the top 3 for most bang for your buck...especially considering I got em for 425
Old Oct 13, 2004 | 02:22 PM
leolufse's Avatar
leolufse
Focals kick *** as well. But I got these MBs on eBay brand new for $219. Focals are not worth the extra $$ IMO.
Old Oct 13, 2004 | 03:34 PM
buletman's Avatar
buletman
Well, either way, I thank you for the pictures, they are a good visual that I really needed. Thanks again, and you may get one or two pms from me in the future
Old Oct 13, 2004 | 04:42 PM
tractng's Avatar
tractng
leolufse,
Are you sure it is $219 or $319? Also, is your spacer 3/4"? It looks like you have plenty of room from hitting the speaker grill.
If i would to do it over again, I would get the MB quartz too. The infinity perfect 6.1 is kind of large. During high volume, there is contact with the speaker grill (i shaved the most of the inner grill off too) and i just powering them with 50rms per channel.
How hard is it to cut the slot for the tweeter? From 1-10, what would u rate. Right now, i have my tweeter glue at that location, but I would like to have it sit flush like yours? What tools did you use.
Thanks,
Tony
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
