pre-wired for satellite?
Old Nov 4, 2004 | 10:45 AM
useful_tech's Avatar
useful_tech
Appreciate the zboater thought.
The problem is that the Bose head unit is sirius compatible.
We need to know specifically whether the N-Bus cable harness is installed from the bose back to the area behind the passenger seat in the ROADSTER.
Surely, someone has made this installation and can answer this question.
If the cable harness is installed, is the tuner from grubbs generic nissan oem Sirius the correct tuner.
Do we need the extender N-Bus cable
Can the tuner be mounted in the roadster in the same location as it is mounted in the coupe?
Where are the installation gurus? We need help with this.
Thanks to all.
Old Nov 13, 2004 | 08:30 AM
ZeddyRoadster's Avatar
ZeddyRoadster
I think I noticed the '05 online options page at nissanusa.com showing both a Sirius and XM option. I have a 2004.5 (April build) Roadster and would love to add XM if it can be done, using the Blose head unit for a 'similar' price to replacing everything.
I'd of course use an alternate antenna location to the factory design.
Out of curiosity I'd be most greatful to anyone that could dig up a part number for the factory (presumably dealer-installed?) kit, and a price too. We aren't allowed such niceties from Nissan Canada.
Thanks!
Bob
Old Nov 13, 2004 | 09:23 AM
Teez Zee's Avatar
Teez Zee
The dealers are absolutely o help on this one. My Dealer Empire in Denver says that since the roadster wasn't pre-wired for xm, it can't be done. No thought process added in that statement.
Can anyone that has torn apart their roadster let us know if the harness from the bose unit to behind the passenger seat is installed? If so, all we have to do it mount the tuner and add an antenna. Otherwise, we have to add the n-bus.
All of the parts that we need are available at grubbsparts.com
Gurus - please help
Old Nov 13, 2004 | 10:20 AM
ZeddyRoadster
Unfortunately the fine print goes on to say "Not available with Roadster models" and "vehicle must be factory pre-wired for satellite radio" so when you add them up I would doubt *anything* but the possibly/probably compatible head unit is in place. I don't mind adding the rest including hiding the receiver in the trunk or storage area where Nissan doesn't want to put it.
Bob
Old Dec 16, 2004 | 01:51 PM
laswyguy's Avatar
laswyguy
Ok. So I talked to Nissan parts and service department, and they told me the Touring model, with the Bose Headunit comes with a factory Sat Outlet. (No Roadster).
All you have to buy is the Sirius or XM Tuner - $320
Antenna - $14
Harness - $58
$392- total. and its plug and play (not including installation).
The dealer wanted $491 to intall this!! If you can believe this..
The alternate is to do like what the other guy did.
Buy the PAC- AAI-NIS audio input and hardwire it in. - $76
Sirius Tuner from Best Buy or wherever - $100.
So total = $176 + labor, considerably cheaper, but i suppose to need to hide the after market unit.
Old Dec 17, 2004 | 07:06 AM
ZeddyRoadster
Wow, so that parts guy is basically saying the Roadster head unit is a different part number since it hasn't got the satellite input. I wouldn't have figured them to bother subbing a second Clarion model between the two vehicles, especially if the sat-ready unit is also offered in other Nissan lines.
Old Dec 17, 2004 | 09:25 AM
useful_tech
This makes absolutely no sense.
Can't someone get the oem part number for both the roadster and coupe so that we can answer this question forever. BTW - the cable that is missing is only a 4 wire cable. If we can find the part number for the connectors, the cable would be duck simple to make.
Old Jan 3, 2005 | 12:55 AM
BlueDragonZ's Avatar
BlueDragonZ
So if I have just an 03 Touring, do I just use a LOC instead of FM Mod so the audio is CD quality? I'll be installing an XM Terk Commander.
Old Jan 11, 2005 | 12:48 PM
Hupperware's Avatar
Hupperware
I believe what he is saying is the roadster has the same head unit, but doesn't have the N-bus wire run. The N-bus wire is the part that pulgs into the stock sat receiver box. That being said, you need the PAC unit so that you can interface a PNP unit to the stock head unit.
zpylot
Jul 9, 2005 04:33 PM
PhoenixINX
Jul 17, 2003 10:35 PM
theZman
Jul 10, 2003 05:34 AM
LemanZ Sunset
Jul 9, 2003 10:47 PM
