Audio Builds Audio projects and builds from my350z members
New Sub box design
Old Jan 9, 2006 | 10:40 AM
  #41
16psibrick's Avatar
16psibrick
Simplicity in Sound
hey, a while back, i did an isntall on a Z and replaced the two foam pieces below the trunk with enclosures housing two solodbaric 8s, and it sounded pretty darn good...
perhaps you canlook into building something like that? i think it would be a great seller
Old Jan 10, 2006 | 12:42 PM
  #42
navynukeme's Avatar
navynukeme
I cant say enough good things about this box!! It doesnt have a amp rack on the back but I had it mounted and sealed the right way. Having my windows tinted prevents it frome being seen that well but there are many other oprions for amp mounting with the Z. The install is as easy as a normal box (just slides under the strut with a little push). the carpet matches the interior perfectly and the sound is just enough. I have two JL audio 10" W3 in there. Highly recommended!!!
Old Jan 10, 2006 | 03:39 PM
  #43
therock2689's Avatar
therock2689
R u goen to make anything for a single 12 in the coupe???
Old Jan 10, 2006 | 05:15 PM
  #44
05-Z's Avatar
05-Z
I wouldn't mind a single 12 either, I would rather have this than two 10's.
Old Jan 11, 2006 | 10:42 AM
  #45
therock2689
I like single 12 cause i think it looks cleaner and its normally less weight then a 2 10's, less power, but in teh end it all personal preferance.
Old Jan 11, 2006 | 10:52 AM
  #46
mlg9770's Avatar
mlg9770
ZEnclosures
I do have a couple designs for a single 12" sub. One sits in front of the strut bar and the other is a spare tire well box. The one in front of the strut bar is functional but not that custom of a fit. The spare tire box you have to sacrifice your spare.....this is the box I use but for 2-10". I carry a 12 volt pump, plug kit, and worse case a can of fix-a-flat.
I just got back from Sound Advice and they were nice enough to let me test fit a JL 10w7 and an Alpine Type X in the newly designed box....both fit with no problem at all.
mike
Old Jan 11, 2006 | 05:10 PM
  #47
therock2689
When ever u figure out the numbers on the 12 box, drop us a line please. Both price and volume when ever u can, Thanx in advance.
Old Jan 16, 2006 | 07:51 AM
  #48
james840a's Avatar
james840a
would that box design fit 2 Alpine Type-X 10"?
Depth and Volumn?
Im thinking about getting 2 type-x and new box for my z and i like that design
Old Jan 16, 2006 | 08:05 AM
  #49
mlg9770's Avatar
mlg9770
ZEnclosures
Depth and Volumn?
I have test fit the Type X and they do fit. For the 2-10" version your looking at approx. .67 per woofer/side of airspace which is within the specs for this sub.
Friday I dropped off this box for install using a single Type X with a port. The owner called me this morning and said it sounds fantastic. This was good news since I've never done any porting. Once I hear it for myself I'm sure I'll be switching over to this design.
I will have pics of his install later this week after he stops by.
thanks mike
Alpine Type X
10" subwoofer with dual 4-ohm voice coils
carbon fiber/aluminum honeycomb cone
high-roll Santoprene rubber surround
cast aluminum frame
frequency response 24-200 Hz
power range 500-1,000 watts RMS (500 watts per coil)
peak power handling 3,000 watts
sensitivity 81 dB
top-mount depth 8-5/8"
sealed box volume: 0.5-1.0 cubic feet
ported box volume: 0.8-1.5 cubic feet
Recommended Q-Logic Box Type: 1, 2, 3
warranty: 1 year
Old Jan 16, 2006 | 08:11 AM
  #50
eckocomplexg's Avatar
eckocomplexg
i'm getting my box today..... i can't wait man! unfortunately i will only have one sub until about friday..
Old Jan 16, 2006 | 08:12 AM
  #51
eckocomplexg
im using infinity perfect 10.1 btw
Old Jan 16, 2006 | 08:19 AM
  #52
mlg9770's Avatar
mlg9770
ZEnclosures
After test fitting the box in my 2005 and then in a 2006 I noticed Nissan has added a .30" rubber seal/gasket under the edge of the plastic spare tire cover. This raises the floor slighty and makes the box harder to get in. If you have a 2006 and have any trouble during install you can remove this seal or take the secondary grey trunk mat out of the car.
mike
Old Jan 16, 2006 | 08:23 AM
  #53
eckocomplexg
i've got an 04.. i'll make it fit one way or another
Old Jan 21, 2006 | 02:08 PM
  #54
mlg9770's Avatar
mlg9770
ZEnclosures
Here are a few pictures from the first install of this new box. Sounded great with the port.
The installer(CC) didn't push the box all the way in properly when he attached the amp rack so it does have to go back and get reinstalled.
Also, here's a pic of my car....finally almost done.
mike
Attached Thumbnails New Sub box design-dsc03123.jpg   New Sub box design-dsc03181.jpg   New Sub box design-dsc03180.jpg   New Sub box design-dsc03178.jpg   New Sub box design-dsc03146.jpg
Old Jan 21, 2006 | 02:24 PM
  #55
eckocomplexg
Mike I installed my box yesterday. OMG it's so kick *** dude it makes my stereo setup sound so damn powerful
I'll send you the pics you requested as soon as i can .. i've been a little sick so I've been in my room for quite a while... I just had to get out of bed yesterday to install it.. lol
Old Jan 21, 2006 | 02:43 PM
  #56
Hybrid90's Avatar
Hybrid90
Mike, do you have a custom box that fits in the stock subwoofer location for an 05 Base model? Thanks!
Old Jan 21, 2006 | 03:21 PM
  #57
vitaminZ's Avatar
vitaminZ
mike
looks damn good mike!!! i see that your Z is coming along.
Mike puts out some quality stuff, no ifs, ands or buts about it!
Mike, i'll be back from my deployment soon. i'll hit you up once i am back. maybe we can try to make it to show together. i am moving to New Jersey but frst i will have a short stint in Maryland. perhaps you can come up for SEMA or HIN in atlantic city!!
keep up the good work.
Old Jan 21, 2006 | 03:40 PM
  #58
xtrememan315's Avatar
xtrememan315
that would be nice if it were say for a single sub ported.... i don't think .7 per sub is good ported... i don't think he would make a ported box since there are too many variables in different subs.
I agree, to be a ported box you need well over 1.0 per sub and thats a good estimate for any two subs.
I have a ported enclosure and it takes up the entire rear (including spare tire location) and I have almost 4.0 cubic feet! (TIGHT FIT LOL)
Old Jan 21, 2006 | 03:42 PM
  #59
xtrememan315
Oh not to mention the port size would have to be pretty large for small enclosures. I have 2 ports both same size. (Each is big enough to fit my fist in)
Old Jan 21, 2006 | 03:58 PM
  #60
eckocomplexg
when i had my a camry i used to have two alpine type r 12". i had a 3.50 cu ft. ported box. That thing was LOUD!!!
