Audio Builds Audio projects and builds from my350z members
New Installed DDX8019 W/LZ702W Touchscreen
Old May 17, 2008 | 11:30 AM
  #81
haeshik's Avatar
haeshik
sweet setup
Old May 17, 2008 | 03:31 PM
  #82
PrevWon's Avatar
PrevWon
Originally Posted by Spike100
Here is a link that might answer your questions:
http://www.mynismo.com/products/?id=4445
--Spike
So it's just a visibility issue?
Old May 18, 2008 | 07:38 AM
  #83
Spike100's Avatar
Spike100
^^ The the rear pocket on the cubby in the 2003 center console unscrews, making it easier to install a monitor.
--Spike
Old May 24, 2008 | 12:50 PM
  #84
kaspia's Avatar
kaspia
--Spike
I am looking into a dual-screen setup too.
I just ordered it.
Old May 30, 2008 | 06:46 PM
  #85
PrevWon's Avatar
PrevWon
I just ordered it.
Here is a video demo to help other visualize how the lid retracts.
Video of the 03 Lid Cubby Cluster
Where did you order yours from?
Old May 30, 2008 | 07:23 PM
  #86
kaspia's Avatar
kaspia
I ordered it from mynismo.com -- from the previous link that Spike suggested to you.
Old May 30, 2008 | 07:47 PM
  #87
PrevWon's Avatar
PrevWon
Okay cool, I ordered it elsewhere and I thought they only sent me half of the cubby lol I thought it came with the back half too.
EDIT: What's that in the silver Nissan box?
Old May 30, 2008 | 08:00 PM
  #88
kaspia's Avatar
kaspia
Its the storage mini box (you won't need this if you are planning to install a LCD in the cubby.
Old May 30, 2008 | 08:04 PM
  #89
PrevWon's Avatar
PrevWon
Oooh okay that's what I thought came with it.
Old Jun 2, 2008 | 07:05 PM
  #90
Sandy@ART's Avatar
Sandy@ART
Originally Posted by doug
hella is the name of a company that makes lighting products
I was thinking the same thing...i swear you kill me..i love reading your comments...lol..
Old Jun 3, 2008 | 09:46 AM
  #91
ncparamedic's Avatar
ncparamedic
Prodigal Son
Spike,
Where did he get the trim peices to fit the cubby..was that a custom thing?
Old Jun 3, 2008 | 04:35 PM
  #92
Spike100's Avatar
Spike100
^^ I didn't need anything other than the stock OEM cubby. I have a 2003 cubby, and simply removed the cubby's rear pocket (it unscrews in the 2003 cubby), and dropped the monitor in place. Just the tight fit would hold the monitor in place, but I used the original screws to add a measure of security. The original screws were tightened lightly into the sides of the monitor.
Hope that explanation is clear and not confusing.
--Spike
Old Jun 3, 2008 | 05:27 PM
  #93
ncparamedic
Prodigal Son
so do you think i will need to replace the cubby in my 07?
Old Jun 3, 2008 | 08:05 PM
  #94
PrevWon's Avatar
PrevWon
If I'm not mistaken, you can't do this in an 06-08. The cubby swap won't work and you can't fit a screen in the cubbies they come with. Correct me if I'm wrong though.
Old Jun 5, 2008 | 02:03 PM
  #95
ncparamedic
Prodigal Son
^^ can someone answer this??
Old Jun 5, 2008 | 07:39 PM
  #96
Spike100's Avatar
Spike100
^^ You can’t swap out the 2007 cubby with a 2003 cubby, so that “easy 7-inch LCD monitor mount capability for the 2003 cubby” isn’t an option in the 2007 car.
Mounting a LCD screen in the 2007 model requires some custom fabrication. You need to cut-out the rear part of the cubby, fabricate a “harness/strap-up” to hold the screen in place, and fabricate trim pieces to flush-fit the forward part of the monitor.
Judging from the lack of responses, I suppose that most people consider this a lot of work and expense when comparing to how easily you can install an “all-in-one” double-din device with a 7” LCD screen inside the Z’s available lower slot.
Of course, there are advantages to mounting a LCD screen in the upper/forward cubby (this position looks great, is more easily viewed, and it's a "natural").
I hope there is a response from someone who has done this.
--Spike
Old Jun 6, 2008 | 08:11 AM
  #97
Kal_El's Avatar
Kal_El
I finally got to see Duke and he took care of me. Thank you Spike and Duke for facilitating my questions and pointing me in the direction.
https://my350z.com/forum/audio-and-video/364545-kenwood-navigation-in-03-cubby-install.html
Old Jun 6, 2008 | 08:46 AM
  #98
ncparamedic
Prodigal Son
--Spike
Well ill try it as soon as I get home. The worst Ill have to do is to buy a replacement cubby for my 07 I dont believe it will be any harder than a little careful dremeling and some brainstorming. There has to be a way to get it to work..
Thanks Spike.. Again i appreciate the help.
Old Jun 6, 2008 | 11:19 AM
  #99
ncparamedic
Prodigal Son
Spike,
Would this be an option..smaller screen but do you think the 07 cubby would fit this better?
http://www.kenwoodusa.com/Car_Entert...84%A2/KOS-L432
Old Jun 6, 2008 | 06:07 PM
  #100
Spike100's Avatar
Spike100
Spike,
That will work, and it’s probably easier to mount. With this said, I’m not a fan of 4.3” monitors. A seven-inch monitor in the upper/forward cubby is more easily viewed and provides a much better view and touchscreen function. But, this is a personal opinion since I like an OEM look.
Installing a 4.3” monitor in the upper/forward cubby won’t require custom fabrication (it will fit inside the cubby without doing anything else). If you decide to do this, you could also go with a Garmin Nuvi since it fits and is detachable for use when leaving the car and going “on foot.”
But then again, controlling the entire CES via a KOS-L432 Touchscreen 4.3” Monitor is a very attractive option. The fact that you can fit this in the upper/forward cubby without custom modification is a major plus.
Hopefully there is someone who has installed (or planning to install) a 7” LCD monitor in the upper/forward cubby in a 2006 or later model Z. But, being a realist, I doubt this is the case; and the lack of posts for this show that most people find it easier to simply install an “all-in-one” device in the Z’s double-din slot.
And once again, I’ve managed to post a long and somewhat confusing message.
--Spike
