Audio Builds Audio projects and builds from my350z members
Kenwood DDX-7019 installed with pics
Old Jan 1, 2008 | 11:27 PM
SChetal's Avatar
SChetal
Hawt!!
Old Jan 12, 2008 | 11:13 PM
Mr_pharmD's Avatar
Mr_pharmD
can u do video bypass on this unit with just grounding the e-brake??
Old Jan 13, 2008 | 03:24 AM
PoorG35's Avatar
PoorG35
Ipod video plays perfect with no bypass needed.
ebrake wire ground for full functions. no toggle switchs, just ground.
album art looks great, ill take a pic if op doesnt.
on the 7100 there is a mini usb cable plugged into ur deck, you need to use this for image uploads.
a how to for back ground images found here: http://www.avsforum.com/avs-vb/showt...php?p=11017571
Old Jan 13, 2008 | 06:59 AM
yusoslo's Avatar
yusoslo
yeah it irritated me that you cant upload your ipod pics to the headunit, that is why i routed my ipod to the center armrest. the usb port can then be accessed under the shift boot for thumb drive access.
Old Jan 21, 2008 | 04:32 AM
kirradude1025's Avatar
kirradude1025
wat are the steps to remove the actual center dash, i need to reinstall mine. thanks
Old Jan 21, 2008 | 09:46 AM
yusoslo's Avatar
yusoslo
check out the diy sub-forum.....takes about 5-10 min to get it out.
but...
-lift up on shifter surrond and remove.
-removed screws on lower latch on upper cubby hole
-remove all visible screws shown.
-pull towards you
-unclip......gauges, A/C, Radio...you're done!
350Z_Al
Oct 29, 2020 07:44 PM
dcains
Nov 11, 2015 11:36 PM
