Audio Builds Audio projects and builds from my350z members
VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....
Old Jan 11, 2008 | 07:49 AM
  #61
VO...'s Avatar
VO...
Administrator
The beast has arrived! I must say I'm in awe at the size, weight, and construction of the FI sub. The pictures I took do not do it justice. It weighs in @ 30lbs and is just plain out massive. IMO it's construction is superior to the Rockford T1 I previously owned. You can tell the sub was freshly made also, due to the residual smells of new plastics and glue when the box was opened.
I took a close up pic of the mounting hole. The outer rim of the sub has a black rubber finishing ring, which appears to be glued to the sub. When you look into the hole, you can not see through to the other side. I'm assuming it's just because excess glue & material is blocking the view, and I'm suppose to just pierce through it with my mounting bolt. Can somone who's had experience with these subs please confirm this?
Enjoy the pics guys. I will most likely get to the install on Monday, maybe this Saturday if I have time.....
Attached Thumbnails VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3401.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3402.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3403.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3405.jpg
Old Jan 11, 2008 | 08:03 AM
  #62
StreetOC192's Avatar
StreetOC192
Very nice sub!!!
That last pic looks like some of the foam surround is covering the hole. you should be able to punch a screw through that easily. I am curious as to shy they use a foam surround as opposed to a rubber surround.
Old Jan 11, 2008 | 08:13 AM
  #63
VO...'s Avatar
VO...
Administrator
Originally Posted by StreetOC192
Very nice sub!!!
That's what I thought too. I just wanted to make sure it wasn't a removable ring like the ones on JL subs.
As far as the foam goes, your guess is as good as mine. They foam is quite thick though.
Old Jan 11, 2008 | 08:18 AM
  #64
StreetOC192
Well, typically rubber is better than foam only because of durability in the elements. Rubber typically also tends to be more flexible or pliable. However, that's not to say that a foam surround is inferior. It may be a special poly blended foam or something. who knows. It's a damn nice sub either way!
Old Jan 11, 2008 | 08:36 AM
  #65
VO...'s Avatar
VO...
Administrator
Thanks.
Old Jan 11, 2008 | 08:44 AM
  #66
350zspl's Avatar
350zspl
Scott builds to order so yes your Q is fresh off the grill
the parts come from a build house in Cali and are the cadillac of parts
12 spoke design FTMFGDW
i love 12 spoke and that is why all my subs are 12 spoke RE-RD-FI
as far as what RF had made in China and What Scott made for you in Nevada HELL YES IT IS WAAAAAAAAAAAAAAAAAAAAAY better
congrats enjoy and forget about audio pulse
hope your happy
Old Jan 11, 2008 | 08:48 AM
  #67
VO...'s Avatar
VO...
Administrator
hope your happy
Thanks man. This sub is gorgeous in person. I can't wait to install it and crank my amp up. I'm hoping I don't have insufficient car amperage issues once I crank the amp up though....
Old Jan 11, 2008 | 08:58 AM
  #68
350zspl's Avatar
350zspl
do the install
start car
take you volt meter before you turn on stereo , check voltage on underhood battery should read 14 to 14.5 volts
if yes
go ahead and turn on stereo
once it is craked at max desired volume
take volt meter and place - & + probes on - & + power and ground wires at the amp
let me know what you voltage is reading at the amp at idle
13.5 volts or more and your fine
under 13 volts and your gonna need a trunk battery
r
Old Jan 11, 2008 | 09:16 AM
  #69
VO...'s Avatar
VO...
Administrator
do the install
start car
if yes
r
Good idea. I will do that....
Old Jan 11, 2008 | 10:38 AM
  #70
350zspl's Avatar
350zspl
from time to time i have a good idea
Old Jan 11, 2008 | 10:54 AM
  #71
dragone2717's Avatar
dragone2717
Good write up VO... I may need to contract you on some help for my near future project....
Old Jan 11, 2008 | 11:01 AM
  #72
VO...'s Avatar
VO...
Administrator
Thanks Gio...
Old Jan 11, 2008 | 11:11 AM
  #73
dragone2717
Thanks Gio...
No prob.
Gotta hear it at the next meet.
Old Jan 11, 2008 | 11:27 AM
  #74
Crom's Avatar
Crom
Is that yellow box your new antenna booster?...or are you using the stock one?
Old Jan 11, 2008 | 11:35 AM
  #75
USMC-Z's Avatar
USMC-Z
Z Veteran
Looks like a fuse holder.
Old Jan 11, 2008 | 11:43 AM
  #76
VO...'s Avatar
VO...
Administrator
+1. It's supplying a triggered 12vdc to the antenna booster....
Old Jan 11, 2008 | 12:20 PM
  #77
DustinZ33's Avatar
DustinZ33
VO. Where did you get your fi sub? I would like to check into this sub. Do they make 10"?
Old Jan 11, 2008 | 12:25 PM
  #78
VO...'s Avatar
VO...
Administrator
FIaudio.com
Old Jan 11, 2008 | 12:28 PM
  #79
DustinZ33's Avatar
DustinZ33
sweet thanks. I searched on google but nothing.
Old Jan 11, 2008 | 12:29 PM
  #80
VO...'s Avatar
VO...
Administrator
it'll pull it up automatically on Yahoo....
